Re: If you had to run a cast iron intake 440, what to use?
[Re: MRMOPAR622]
#1363422
01/03/13 12:09 PM
01/03/13 12:09 PM
Posts: 52,972 Romeo MI
MR_P_BODY
A few years back an aluminum intake painted blue to match the rest of the engine worked fine for me.Believe me unless there is a Mopar tech or another Mopar racer in your class no one will ever notice.
Way to easy to check for the tech... a magnet does wonders
[Re: MR_P_BODY]
#1363423
01/03/13 12:21 PM
01/03/13 12:21 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
We have doctored an aluminum intake with super fine metal shavings in the past. Passed the magnet test, more or less. lol.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Von]
#1363424
01/03/13 12:30 PM
01/03/13 12:30 PM
MR_P_BODY
I did that once... put metal filings in the paint and brushed it on... if the tech is decent he will know... I didnt get caught
[Re: MR_P_BODY]
#1363425
01/03/13 01:56 PM
01/03/13 01:56 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
Any dual plane intake will perform better with a broader horsepower range if you take the center divider down to 5/8" above the upper floor. That increases total air/ fuel volume to all cylinders.
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
[Re: ademon]
#1363428
01/04/13 01:20 AM
01/04/13 01:20 AM
Posts: 522 Lenox Iowa
MMiller
Lenox Iowa
If its all the same to you guys, we're going to build it legal. I'd rather get second place every weekend and do it legal then win by cheating. Plus, I'm sure Bill would rather not get caught cheating and then not allowed to pull with this organization for a year. I don't know how many times I've heard "That Dodge runs pretty good, he must be cheating". Why give them any more reason to believe that.
Cubes will be under 470.
Michael
93 W250 CTD getrag, Bosch 185 injectors, AFE air filter. Trailer puller, daily driver, 90 W250 CTD 727 with smokin 5" stacks. Off road truck
75 Dodge W200 440 4spd 4x4 locked front and rear, twin disc clutch, E85. Pulling truck
[Re: MMiller]
#1363432
01/04/13 09:04 PM
01/04/13 09:04 PM
Posts: 3,060 Western New York
sixpackbee
Western New York
The 71/72 manifold is the best. It has tow oval openings instead of a four hole. Holley bolt pattern too.
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
[Re: BSB67]
#1363435
01/04/13 11:28 PM
01/04/13 11:28 PM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
FWIW, when I truck pulled several years ago before everyone got stupid on spending ridiculous amounts of money to win a hundred bucks and trophy, I used a 70 model square bore manifold with the divider trimmed down and a 2 inch carb spacer on my 440. The iron intake is a B.S. rule anyway. Look at all of the chevy guys running square port heads, probably Merlins at that, and adapting an oval port cast iron intake to work with the heads. To my knowledege, they never made a square port BBC engine with a iron intake. As far as not cheating and winning, It aint gonna happen. Thats why I quit. EVERYONE cheats. 500+ inch motors on nitrous, hidden vac pumps to pull vac at idle, blocked suspensions, pro fab transfer cases, the list goes on and on....
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: sixpackbee]
#1363437
01/05/13 11:12 AM
01/05/13 11:12 AM
Posts: 2,611 Elbridge, NY
Dart1031
Elbridge, NY
Agreed. I read somewhere that the 71 intakes are also the tallest of the square bore intakes.
[Re: bgilbert]
#1363438
01/05/13 01:33 PM
01/05/13 01:33 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
Are you sure the rules for the intake say 'Cast Iron' and not just 'Cast'. It makes a huge difference because one way it makes the class all about the intake manifold and the other way just rules out expensive hand-fabricated intake manifolds. The rule about iron heads is a good cost-reducing one and allowing any aftermarket cast intake is reasonable since cast manifolds are cheap. Restricting contestants to OEM Iron intake manifolds could really take the fun out of it. I can understand if there's some confusion about the terms 'cast' and 'cast iron' because some people use incorrect or incomplete terminology using the term 'cast' when they mean 'cast iron' or the term 'alloy' when they mean aluminum (that one is really annoying). A set of iron max wedge heads or 440-1's with an indy intake should support a lot more than 470ci. Quote:
I'm sure they'd just make me pull the carb to check with a magnet if questionable. The rules don't say anything about stock cast, just cast. I'm pretty sure the majority of them are running non-oem cast iron. I saw the Indy cast iron heads, but their intakes didn't say whether they were cast or not. I'll start looking for the 71/72 intake. Thanks guys, definitely alot more info/replies than what I expected.
[Re: Skeptic]
#1363441
01/05/13 09:13 PM
01/05/13 09:13 PM
Posts: 33 Terre Haute, Indiana
bgilbert
It's a stock class. Cast IRON intake and exhaust manifolds! Ok just to be sure. Here is a pic of the intake manifold from my stock Dodge truck 75 440. Part # 3830733-2 and 05110 cast into it. I also have the same one on a 73 Dodge truck 440. When you all say 71 TQ manifold, are you not talking about just any TQ manifold? Is the 71 a taller/better manifold? Anyone have a pic? Thank you.
