Andy's w8 turbo engine aka (fishy340) #1363368
01/02/13 09:21 PM
01/02/13 09:21 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
Re: Andy's w8 turbo engine aka (fishy340) [Re: W5DART66] #1363369
01/02/13 09:57 PM
01/02/13 09:57 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
Andy has since moved to Arizona,let me give you his new address.
Re: Andy's w8 turbo engine aka (fishy340) [Re: Darryls-Demon] #1363370
01/02/13 10:16 PM
01/02/13 10:16 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
bad a$$. twins?
Re: Andy's w8 turbo engine aka (fishy340) [Re: Darryls-Demon] #1363371
01/02/13 10:16 PM
01/02/13 10:16 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Re: Andy's w8 turbo engine aka (fishy340) [Re: fishy340] #1363372
01/02/13 11:24 PM
01/02/13 11:24 PM
Orlando Fl
Dos Snails Offline
Dos Snails  Offline
Orlando Fl
How did the Turbo engine like the cast intake with the Wilson elbow? How is the flow per cyc ?
Re: Andy's w8 turbo engine aka (fishy340) [Re: Dos Snails] #1363373
01/03/13 09:17 AM
01/03/13 09:17 AM
San Angelo, Texas
W8n2DustU Offline
W8n2DustU  Offline
San Angelo, Texas
Man that looks familiar! Lol
2010 Toxic Orange Challenger built by B and B Racecars! All aluminum R4/P5 engine, Proformance TH400 (3 speed) tranny, full Reid case, nodular 9" rearend, full Dragpak suspension, Protorque custom converter, BS3, PTE 85mm turbo, fire core wires, carbon doors, carbon front clip, and a whole lot more!
Re: Andy's w8 turbo engine aka (fishy340) [Re: W8n2DustU] #1363374
01/03/13 09:39 AM
01/03/13 09:39 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Nice peace
Re: Andy's w8 turbo engine aka (fishy340) [Re: racerx] #1363375
01/03/13 06:13 PM
01/03/13 06:13 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Dang, no wonder he didn't respond to my email about buying it, it's already at your house! Lol
Re: Andy's w8 turbo engine aka (fishy340) [Re: Dos Snails] #1363376
01/03/13 08:23 PM
01/03/13 08:23 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
I run a cast intake with a Wilson elbow...It is fine... Do you think there would be an issue?
Re: Andy's w8 turbo engine aka (fishy340) [Re: TheOtherDodge] #1363377
01/04/13 02:26 PM
01/04/13 02:26 PM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
What are the oil lines coming from the oil pan for? We have a wilson elbow with a cast indy intake, works just fine. Have been running it for five years now, have been in hte dyno once nad it made 1580 hp at 6100 rpm but the turbos were already out of their range at that point.
Plynouth VIP '67 TT IC EFI
Re: Andy's w8 turbo engine aka (fishy340) [Re: jyrki] #1363378
01/04/13 03:15 PM
01/04/13 03:15 PM
Orlando Fl
Dos Snails Offline
Dos Snails  Offline
Orlando Fl
just asking, because of a post on the turbo forums about the throttle body causing more flow to be fed to the back cylinders than to the front ....
Re: Andy's w8 turbo engine aka (fishy340) [Re: jyrki] #1363379
01/04/13 03:28 PM
01/04/13 03:28 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Return lines for oil.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Andy's w8 turbo engine aka (fishy340) [Re: Dos Snails] #1363380
01/04/13 11:51 PM
01/04/13 11:51 PM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
being a dry intake really mutes that point.....
65 Barracuda
All aluminum Indy HEMI with some boost!
COMING TO A TRACK NEAR YOU!
Re: Andy's w8 turbo engine aka (fishy340) [Re: instigator] #1363381
01/05/13 12:41 AM
01/05/13 12:41 AM
Houston, Texas
Houston, Texas
Re: Andy's w8 turbo engine aka (fishy340) [Re: 1967dartgt] #1363382
01/05/13 05:27 AM
01/05/13 05:27 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
Shouldn't they be above the oil level?
Re: Andy's w8 turbo engine aka (fishy340) [Re: jyrki] #1363383
01/05/13 09:29 AM
01/05/13 09:29 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
The only time oil is level is when the pump isnt whipping it around the engine.
Re: Andy's w8 turbo engine aka (fishy340) [Re: fishy340] #1363384
01/05/13 10:16 AM
01/05/13 10:16 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I seriously doubt there is more than 3" of oil in the pan when its running.
I run 11 quarts in my BB just to have some left in the pan at the end of the quarter.
Lokin Good Andy, Good luck with it!
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Andy's w8 turbo engine aka (fishy340) [Re: Dos Snails] #1363385
01/05/13 10:22 AM
01/05/13 10:22 AM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
My procharged engine liked the intake just fine. If you do your intake cleanup well it will flow air just as good as it will flow air and fuel actually a litle better.
Re: Andy's w8 turbo engine aka (fishy340) [Re: bigtimeauto] #1363386
01/05/13 10:33 AM
01/05/13 10:33 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Thanks Bob,but its actually up for sale.I have to much stuff and 2 set up for spray . Btw Happy New Yr from me and pop the pro charger is rippin in his car.
Re: Andy's w8 turbo engine aka (fishy340) [Re: instigator] #1363387
01/05/13 10:35 AM
01/05/13 10:35 AM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
Yep! Once it's all pressurized container under boost - it's all the same pressure everywhere. Port injection means no issues with distribution, although I have seen differences in fuel delivery from the injectors based on fuel temps when NA. That also becomes a mute point once it's all at WOT and flowing cool fuel.
