Notched counterweights - Is this OK? #1363005
01/01/13 10:08 PM
01/01/13 10:08 PM
Farmington Hills, MI
BPBP440 Offline OP
BPBP440  Offline OP
I just pulled took the shortblock on my 440 apart for the first time. I was surprised at the notched counterweights, which I assume are a result of speedshop balancing. I am used to seeing drilled holes in the end of the counterweight, or removing material along the outside edge of the counterweight. Seems like this would create a heck of a stress riser.
Any experience you guys have with this would be appreciated.
Thanks - Jim
Re: Notched counterweights - Is this OK? [Re: BPBP440] #1363006
01/01/13 10:23 PM
01/01/13 10:23 PM
BPBP440 Offline OP
BPBP440  Offline OP
2nd pic
Re: Notched counterweights - Is this OK? [Re: BPBP440] #1363007
01/01/13 10:33 PM
01/01/13 10:33 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I have seen a lot of counter weights cut like this.....less so on the throws , but I have seen it too.
Is it a problem ?
I wouldn't do it like that , but it is probably O.K. for a modest effort.
For big power , I'd say no way.
Re: Notched counterweights - Is this OK? [Re: BPBP440] #1363008
01/01/13 10:34 PM
01/01/13 10:34 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
seen that on factory cranks before, not nearly as much as drilled holes tho.
Re: Notched counterweights - Is this OK? [Re: tubtar] #1363009
01/01/13 10:51 PM
01/01/13 10:51 PM
BPBP440 Offline OP
BPBP440  Offline OP
Okay, that is a relief. It just looks pretty shoddy, especially on the throws. I will not be going high horsepower; 9.5:1, modest Comp Cams 270H cam, and I do not plan to rev it to the moon.
Re: Notched counterweights - Is this OK? [Re: BPBP440] #1363010
01/02/13 12:16 AM
01/02/13 12:16 AM
2nd pic
Both of those cuts are factory stock I've seen worst
Re: Notched counterweights - Is this OK? [Re: Cab_Burge] #1363011
01/02/13 12:24 AM
01/02/13 12:24 AM
BPBP440 Offline OP
BPBP440  Offline OP
2nd pic
No kidding, right from the factory like this?
Re: Notched counterweights - Is this OK? [Re: BPBP440] #1363012
01/02/13 03:01 AM
01/02/13 03:01 AM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
Those notches are made so each throw is indexed correctly when crank is made.
Re: Notched counterweights - Is this OK? [Re: BPBP440] #1363013
01/02/13 10:14 AM
01/02/13 10:14 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Those notches create more turbulence in the lower end
Re: Notched counterweights - Is this OK? [Re: MR_P_BODY] #1363014
01/02/13 12:57 PM
01/02/13 12:57 PM
organ
maximum entropy Offline
organ
those are for machining reference on factory cranks.
Re: Notched counterweights - Is this OK? [Re: BPBP440] #1363015
01/02/13 08:12 PM
01/02/13 08:12 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Those notches were for locating the crank in the shipping racks at the factory
