Re: Can someone explain...(I'm an idiot)
[Re: Sssnake383]
#136257
10/14/08 02:49 PM
10/14/08 02:49 PM
Posts: 15,487 Florida
scratchnfotraction
yes the ballist res could be bad coil could be bad I used the pertronix unit that replaces the points and have not had to change the pertronix rotor yet,just a new cap now and then I guted the porcilin shell of a ballest res and solderd the ends on a piece of #10 stranded wire to hind the fact it was bypassed you by pass it to give the pertronix the full 12 volts and it has lots of fire with the 40,000 volt pertronix coil easy hook up red to + and black to - side of coil with the one key wire that is on the coil now with you points this was on the 68 Dart,another good upgrade is one of the newer soild state voltage regulaters,it was way better and the lights did not go dim when at idle and lights on I tell you this cause I changed points for 2yrs every 2-3 months with that old car till I replaced it now I have had that same set up in 3 diff cars and 9 yrs with out ever a problem ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: Sssnake383]
#136262
10/14/08 03:11 PM
10/14/08 03:11 PM
Andrewh
Well, by putting in the petronix, you eliminate 2 out of 4 things being bad.
Basically you take out points and the balast being your problem.
The two remaining are the coil and power, which breaks down to two things.
You have key on power in run. That should read 12 volts on one side and around 8 volts on the other of the ballast.
You also have start power which should bypass the ballast and read 12 volts on the coil side when you are turning the key to start the car.
So if you put in the petronix, and the car still doesn't start, then all you have to check is voltage. If there is voltage, then you have a bad coil.
If you try to fix the points, then you have to verify the points aren't burnt out. That they gap is set correctly, then figure out if the coil or ballast is dead. Assuming you have voltage at both run and start.
[Re: Andrewh]
#136264
10/14/08 03:23 PM
10/14/08 03:23 PM
Posts: 1,037 The New Jersey Hinterlands
Sssnake383
Old and boring
Old and boring
I don't want to compound my problems. I would like to fix the points, that way - if I screw up installing the Pertronix - at least I know where to start. Thank you for explaining what to test for at the resistor. I will try that tonight, hopefully. So, if the ballast checks good with KEY ON run 12v incoming and about 8v outgoing, the next thing to check is voltage at the coil with the key on start. I'm looking for 12v at the coil? If then I take the cap off and check out the points and they look good (no pitting or blackened areas), what next? Condemn the ignition coil?
Thanks for your help. I am feeling a bit better about tackling this.
[Re: Sssnake383]
#136266
10/14/08 03:30 PM
10/14/08 03:30 PM
Posts: 25,967 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The "key on" voltage check won't tell you much because the normal RUN circuit is shut off during the start cycle.
On your ballast you will find a double blue wire on one side and a blue/brown on the opposite side. The double blue should have battery voltage only when the key is in the RUN position and the blue/brown should have battery voltage only when the key is in the START position.
[Re: Sssnake383]
#136267
10/14/08 03:31 PM
10/14/08 03:31 PM
Andrewh
Nope can't say it is the coil yet.
You can check the cap and rotor next, and just for kiss, make sure the rotor spins when trying to start the car. Have heard of that, but not seen it. The cap and rotor would only stop or inhibit some firing. Like a miss. Unless it was cracked or the top was missing, you should still get spark. You can check for spark at the coil to be sure. Pull the coil wire instead of a plug wire.
Next up look at the points themselves. Make sure they are opening and closing and the ends are not gone. Though honestly the petronix conversion is so simple, it really took me 15 min to do, I would do that. But if you are stuck on trouble shooting points thats fine.
If the points are not burned away, and are opening and closing, and the distributer is turning, then I would try replacing the coil first.
[Re: John_Kunkel]
#136269
10/14/08 03:43 PM
10/14/08 03:43 PM
Sssnake383
Old and boring
Old and boring
This is different then what I just read from the other posters. So, how do I go about checking the ballast? Just see if voltage exists on the double blue wire side when key is on RUN position...and then verify voltage on the blue/brown wire side with key in START position?
I am getting confused again... ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: Andrewh]
#136271
10/14/08 04:07 PM
10/14/08 04:07 PM
Sssnake383
Old and boring
Old and boring
we are saying the same thing. John just pointed out something I forgot.
If you test in run, you should get the voltages I described. But you are not really testing the problem. Since your car won't start, you need to verify voltage in START, while the car is cranking over. The coil side then should read 12 volts.
This is actually bypassing your balast resistor, so it has nothing to do with your no start problem.
OKAY, I see what you guys are saying. So the ballast resistor is not my problem, because the START circuit bypasses it. The RUN circuit uses the ballast to step down voltage so it won't burn up my points. The coil side (of the ballast) needs to read 12v with the key in the START position (car is cranking). Do I have the idea? If the coil side measures 12v (and points check out) then out comes the coil. If the coil side does NOT read 12v, then my problem is...ignition switch or firewall bulkhead. Is this correct?
