Page 1 of 3 1 2 3
408 stroker do's/donts #1361872
12/30/12 10:58 PM
12/30/12 10:58 PM
bc canada
67valiant Offline OP
bc canada
ok give me the low down on a 408 storkeri got the kits coming its a scat eagle crank forged piston 11.5-12.5 and good rods going with a 600 roller cam so what oiling mods should be done do i really need to 4 bolt main the block? not looking to make huge power just enough to get into the low 11 high 10 the kit comes balance and got a sfi balancer so i will send it out agian to get it re balanced so where do i start
Re: 408 stroker do's/donts [Re: 67valiant] #1361873
12/30/12 11:09 PM
12/30/12 11:09 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Plenty of great info already in the tech archive/best of Moparts. Huge detailed database.
Set enough $$$ aside for good heads that will flow at least 270 by .550 lift, the more the better, otherwise the motor won't want to pull in the upper ranges.
Don't overcam or run too loose a converter unless your combo is very light. Strokers love single plane intakes and big cfm carbs when you build them at or above the 10.75:1 range.
Lots more will chime in , just want to get the thread rolling
WIZE
In Car:
Re: 408 stroker do's/donts [Re: 67valiant] #1361874
12/30/12 11:13 PM
12/30/12 11:13 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
No on the 4 bolt main, I went with studs & 2 bolt pro gram center caps, There was a good post on Moparts for small block oil mods a wile back, I think it was from a guy named Herb McCandless... not sure on the spelling...
Re: 408 stroker do's/donts [Re: emarine01] #1361875
12/31/12 01:02 AM
12/31/12 01:02 AM
bc canada
bc canada
thanks guy yup heads are ported iron with 2.08 in 1.60ex good valve job 2" headers car is light 2800 valint 3000 with me in it and getting lighter every day ladder bars 456 gears 5000 stall 727 cheata rev valve going to t brake next
Re: 408 stroker do's/donts [Re: 67valiant] #1361876
12/31/12 07:11 AM
12/31/12 07:11 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
You're gonna run alot faster than your goal with that. .
Re: 408 stroker do's/donts [Re: 67valiant] #1361877
12/31/12 10:14 AM
12/31/12 10:14 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Here is a do(use a guy like Brian at imm) to order a rotating assembly for you...its way worth a very sm fee.It will be right.Hereb is a dont( be wary of claims by dealers in magazines hp claims w there cams) been there done that.
Re: 408 stroker do's/donts [Re: 67valiant] #1361878
12/31/12 11:13 AM
12/31/12 11:13 AM
Az
Crizila Offline
Crizila  Offline
Az
You might want to purchase "Big-Inch Mopar Small Blocks". by Jim Szilagyi. www.cartechbooks.com.
Fastest 300
Re: 408 stroker do's/donts [Re: Crizila] #1361879
12/31/12 12:03 PM
12/31/12 12:03 PM
A high quality oil pan is a must--Charlies comes to mind--the deeper the better as the 408's can and do act like a blender with crank case oil--run as little oil as possible ( I just don't think you need 7 qts) run six or less.
Some can hit a standard dipstick, be sure and check that during build.
Vent valve covers well and keep breathers near the front for sure.
A good one feels like a big block, you are going to have some fun! I agree with Wise, they likey some good heads--do not skimp on rocker arms--get some good ones.
Re: 408 stroker do's/donts [Re: ] #1361880
12/31/12 02:08 PM
12/31/12 02:08 PM
bc canada
bc canada
thanks guy and yup the book is on its way lol now what carb to run i run 1/8 up here but do go to the 1/4 at a different track but not to much
Re: 408 stroker do's/donts [Re: 67valiant] #1361881
12/31/12 02:21 PM
12/31/12 02:21 PM
V
viperblue72 Offline
viperblue72  Offline
V
I ran a 10.5 to 1 408 in 3150lb duster. With mild ported eddies and 248/577 roller 3k stall and 4.10s ran 11.20s@118. Put on indybrocks, and ran 2 passes only went 11.09@122 with bad 1.65 60ft.
No oiling mods, but 7qt pan. Ran it to 6800 rpm all the time. Also carb I ran was proform 950. Intake was an m1 then a victor.
You will be surprises how well it will probably run.
Re: 408 stroker do's/donts [Re: fishy340] #1361882
12/31/12 03:16 PM
12/31/12 03:16 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Very good advice, one magazine writer also comes to mind when you say this.
Mo' Farts
Moderated by "tbagger".
Re: 408 stroker do's/donts [Re: viperblue72] #1361883
12/31/12 03:26 PM
12/31/12 03:26 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Fun motor, mine is 13.0 to 1 comp and lg port Commando's .688int-.672ex roller set-up and Indy int w/1050 dommy,,5900stall,904, 4.56 dana,,,I twist it to 6800 at each shift and run's 10.00's to 9.90 all day long.
Re: 408 stroker do's/donts [Re: 67valiant] #1361884
12/31/12 04:49 PM
12/31/12 04:49 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Measure everything twice amd take good notes as you go. Also I don't think it'll need 4.56 gears. My street/strip Dart is 3260# with me in it, 408, 10.9-1 with a flat solid cam and ported edlebrocks runs high 6.50 in good air and high 6.60s in street trim in the heat with 4.10 gears and a 28" tall radial.
Re: 408 stroker do's/donts [Re: justinp61] #1361885
12/31/12 04:58 PM
12/31/12 04:58 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Justin,
What converter are you running with your combo?
WIZE
In Car:
Re: 408 stroker do's/donts [Re: Streetwize] #1361886
12/31/12 05:55 PM
12/31/12 05:55 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Justin,
Its a Edge Racing 9.5" that flashes 5000. I've been 1.38 60' but usually goes 1.40-1 on radials.
Re: 408 stroker do's/donts [Re: justinp61] #1361887
12/31/12 06:40 PM
12/31/12 06:40 PM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
You mentioned forged pistons, but what about the crank? A friend of mine bought a so-called forged stroker kit which meant forged pistons but he got the cast Eagle crank, and the I-beam rods. If they sell the kit with forged crank they call it the "racing"-kit. He had to buy a 4340 steel crank as the first thing to do....2. was a set of good H-beam rods. Supplier took the infamous cast crank in exchange. I would say cast Eagle crank for Mopar is don't. Cast Scat/MP crank OK. Forged Eagle crank OK (enough). Check this before going further.... My
Re: 408 stroker do's/donts [Re: Oyvind Mopar] #1361888
12/31/12 07:15 PM
12/31/12 07:15 PM
bc canada
bc canada
this is the kit i ordered
360 Main 4340 Forged
Competition Rotating Assemblies
360 Main, 4340 Standard Weight Forged Cranks, I-Beam Connecting Rods
with 7/16" Cap Screws
INTERNAL BALANCED ROTATING ASSEMBLIES
08 4-360-4000-6123-2123 2-ICR6123-2124 4.000" 6.123" FORGED 4.030 FLAT 12.1 11.3 10.8 1-48033 1-48033BI
right now i have a strip dom intake but looking at a m 1 and can get a 850 speed demon carb right now i have a worked over 750 that flows good
Re: 408 stroker do's/donts [Re: 67valiant] #1361889
12/31/12 07:58 PM
12/31/12 07:58 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
I wouldn't take an eagle crank for a mopar period. Especially not a cast crank. The H-beam rods are good though. Not afraid of the Scat I beam rods either.
Re: 408 stroker do's/donts [Re: dodgeboy11] #1361890
01/01/13 09:08 AM
01/01/13 09:08 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Friend with a Dakota broke one inside a few miles right at the number 7/8 journal. Eagle told him his transmission broke it shifting to hard!
I kid you not... He is still pissed off, they refused to make good on it.
Re: 408 stroker do's/donts [Re: gdonovan] #1361891
11/01/14 11:05 PM
11/01/14 11:05 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Yeah, mine broke between #1 rod and main. They told me detonation did it. After getting the supervisors involved, they sent me a new crankshaft. I gave it away.
Page 1 of 3 1 2 3
