e body cup holder............ #1361282
12/29/12 11:42 PM
12/29/12 11:42 PM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
has anyone modified a console door with cup holder inserts?
Re: e body cup holder............ [Re: 05dakota] #1361283
12/30/12 12:00 AM
12/30/12 12:00 AM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
With all due respect, I sure hope not.
Re: e body cup holder............ [Re: Pacnorthcuda] #1361284
12/30/12 12:03 AM
12/30/12 12:03 AM
BDW Offline
BDW  Offline
I'm curious too, need a spot for the big gulp!
What about a hole in the top plate?
Re: e body cup holder............ [Re: BDW] #1361285
12/30/12 12:06 AM
12/30/12 12:06 AM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
Make an insert for the console glove box?
-Daty
Re: e body cup holder............ [Re: Daty Rogers] #1361286
12/30/12 12:14 AM
12/30/12 12:14 AM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
possible, wonder why nobody makes it
Re: e body cup holder............ [Re: 05dakota] #1361287
12/30/12 12:30 AM
12/30/12 12:30 AM
Doniphan, Nebraska
Lmopar69 Offline
Lmopar69  Offline
Doniphan, Nebraska
Cup holders are for minivans. I do it the old fashioned way and spill my coffee in my lap while I drive.
NRCA Member
Re: e body cup holder............ [Re: Lmopar69] #1361288
12/30/12 06:11 AM
12/30/12 06:11 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I haven't seen one for an E-body.
But E-bodies have a large flat area between the shifter and console door. I've seen many woodgrain inserts stained from someone putting a drink there.
I think I've seen can holder that are weight and/or have straps on them. Maybe you could place one of the flat woodgrain of the console and have straps with velcro to hold it down so you can remove easy.
When I was driving across country in my 68 Barracuda, I unbolted the ashtray and hot glued a square plastic tupperware cup under the square opening. It fits a soda can with a koozie/can cooler.
The hot glue can be broken off the chrome and you can later re-bolt on the ash tray and sliding door assembly and not permanently alter anything.
With some more effort I could have left the sliding ash tray door on and you would never know it was a cup holder with the door closed.
Re: e body cup holder............ [Re: autoxcuda] #1361289
12/30/12 06:20 AM
12/30/12 06:20 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I'm thinking a weighted soft rubber/cloth/plastic cupholder that had two elastic straps that would rap around your chrome console insert and have velcro attachment to the cupholder so you could remove it.
I couldn't find one on the internet with some quick searching. You probably would have to find something that had some of those elements, then make the rest.
Sort of like combining these pictures
Re: e body cup holder............ [Re: autoxcuda] #1361290
12/30/12 08:10 AM
12/30/12 08:10 AM
OWL
Culvers Offline
Culvers  Offline
OWL
Culvers
Re: e body cup holder............ [Re: Culvers] #1361291
12/30/12 09:16 AM
12/30/12 09:16 AM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
Leave that E body alone! Go buy a Ford something or other and rip it up. But if you must have a cup holder, here's one for cheap money (.95). Easy install, easy remove.
Re: e body cup holder............ [Re: 05dakota] #1361292
12/30/12 09:18 AM
12/30/12 09:18 AM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
Our E-body has a cup holder. It's the person in the passenger seat.
Re: e body cup holder............ [Re: Culvers] #1361293
12/30/12 09:24 AM
12/30/12 09:24 AM
BDW Offline
BDW  Offline
Ha, exactly! But is there room to adapt a single spot with the shifter still there? Easy enough to cut a hole in the top plate, heck you could even fix it later if you wanted, with a simple patch and new overlay.
Re: e body cup holder............ [Re: Culvers] #1361294
12/30/12 10:13 AM
12/30/12 10:13 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Never seen anything like it, is that your car?
Re: e body cup holder............ [Re: Challenger 1] #1361295
12/30/12 10:30 AM
12/30/12 10:30 AM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
this one fits in the ash tray. not sure if it's still ava.
http://www.cuda-challenger.com/cc/index.php?topic=82916.0
Gary.
Re: e body cup holder............ [Re: Mr340] #1361296
12/30/12 12:59 PM
12/30/12 12:59 PM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
its not
Gary.
Re: e body cup holder............ [Re: 05dakota] #1361297
12/30/12 01:15 PM
12/30/12 01:15 PM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
Re: e body cup holder............ [Re: 05dakota] #1361298
12/30/12 01:33 PM
12/30/12 01:33 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
Remove the console door and make an insert. You could prob. fit two cup holders in that space. I'd make it out of wood
Re: e body cup holder............ [Re: nomore65BelvJim] #1361299
12/31/12 12:11 AM
12/31/12 12:11 AM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
I just Stick with screw cap sodas and water while in the chally...but I do wish I could have my coffee.
Re: e body cup holder............ [Re: Quicksilver440] #1361300
12/31/12 02:38 AM
12/31/12 02:38 AM
Walnut Creek, CA
blown340 Offline
blown340  Offline
Walnut Creek, CA
As a full on coffee addict with a E-body that gets alot of miles on it, I had the same question. The top plate of my console was junk anyway (and still is) so I cut a coffee cup sized hole in the top of it behind the shifter. It works really well for day to day use, but isn't deep enough if I get aggressive in the twisties. It works fine for commuting and cruising though. I'll get a pic at some point and add it to this thread.
-Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah 71 valiant scamp 318/A833OD/AC/PS 00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process 73 W200 Power wagon, PTO winch, 4 spd
Re: e body cup holder............ [Re: blown340] #1361301
12/31/12 10:54 AM
12/31/12 10:54 AM
BDW Offline
BDW  Offline
Would love to see a pic.
Rather than just cutting a hole, what about grafting in a container?
This would add depth for more hold?
