Minimum quench ? #1361024
12/29/12 07:05 PM
12/29/12 07:05 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
What would be the minimum clearance between piston and head ? is .019 too little using H beam scat rods ?
Dan
Re: Minimum quench ? [Re: Wedgeman] #1361025
12/29/12 07:14 PM
12/29/12 07:14 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
need .040
Re: Minimum quench ? [Re: Wedgeman] #1361026
12/29/12 08:31 PM
12/29/12 08:31 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Dan
Thats about .010 too close
Re: Minimum quench ? [Re: CSK] #1361027
12/29/12 08:59 PM
12/29/12 08:59 PM
Washington
skrews Offline
skrews  Offline
Washington
.040
Re: Minimum quench ? [Re: Wedgeman] #1361028
12/29/12 09:17 PM
12/29/12 09:17 PM
Dan
Probally to close What psiton type and materials are yours and how much piston to cylinder wall do you have now? My pump gas 518 C.I. stroker with .0065 piston to cylinder wall clearance was rocking over enough to make it look like it was hitting the edge of the pistons on the combustion chamber edges when warmed up (190F) and revved up above 7000 RPM with .035 cold checking clearances( make sure and rock the piston all the way to the outside of the block and the same on the inside(cam side) I increased the head gasket thickness .008 to get .043 minimum I was trying to follow the recommendations of using .035 with steel rods and forged pistons That worked fine on the iron, open chamber 906 heads, not so good when I swapped the heads to a set of close chamber Eddy RPM aluminum heads
Re: Minimum quench ? [Re: skrews] #1361029
12/29/12 09:18 PM
12/29/12 09:18 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
just use head gasket to make up difference .036 minimum but .040 optimum
Re: Minimum quench ? [Re: Wedgeman] #1361030
12/29/12 09:55 PM
12/29/12 09:55 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
way too close , you want to get as close to .040 as possible
Re: Minimum quench ? [Re: Wedgeman] #1361031
12/29/12 10:41 PM
12/29/12 10:41 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
I've run .038 on a 4.030 bore with .0025 piston to wall and stock rods with no problems. At .035 I would get nervous.
Re: Minimum quench ? [Re: CSK] #1361032
12/29/12 11:37 PM
12/29/12 11:37 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
need .040
Really.
Re: Minimum quench ? [Re: 5spdcuda] #1361033
12/29/12 11:38 PM
12/29/12 11:38 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
We ran .032 on 4.030 bore cast piston stock rod with .004 skirt cl to 7k and never hit with W2 econos open chamber, some have posted .028 on a tight small block, The quench effect will fall off rapidly after .040.
Re: Minimum quench ? [Re: 5spdcuda] #1361034
12/29/12 11:39 PM
12/29/12 11:39 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I set up a 440 with KB hyerutectic's at .035. Mild hydralic cam, steel rods, never see's 6000rpm. Works great but was a pain in the butt setting the quench distance that close.Dave
Re: Minimum quench ? [Re: 5spdcuda] #1361035
12/29/12 11:47 PM
12/29/12 11:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I ran .032 on a 4.070 bore and it just touched at 8000 rpm
in one spot... I hit it with a die grinder on the heads
and it was fine
Re: Minimum quench ? [Re: MR_P_BODY] #1361036
12/29/12 11:57 PM
12/29/12 11:57 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Ok
Thanks for all the responses !
Dan
Re: Minimum quench ? [Re: MR_P_BODY] #1361037
12/30/12 12:06 AM
12/30/12 12:06 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Most of the time a piston strikes the head its from the piston rocking
in the bore, I know this will not sit right with some but if the piston just kisses the head it will just rock back This is not the best thing but I have seen a fellas 383 sbc @ .028 turn 8500 for years with the pistons hitting the head... it just leaves little marks
Re: Minimum quench ? [Re: emarine01] #1361038
12/30/12 12:40 AM
12/30/12 12:40 AM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
.040 to be safe. As per previous post...Piston rock.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Minimum quench ? [Re: Adobedude] #1361039
12/30/12 06:38 AM
12/30/12 06:38 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
When you can read the piston # on the head its just right.
Re: Minimum quench ? [Re: RemCharger] #1361040
12/31/12 12:44 PM
12/31/12 12:44 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
That's what I always heard for race engines too...
On my street/strip stuff I run .030-.040 depending on the compression hieght and bore size. Tighter is better and with good equipment and operator it's as easy as having the machining operations done.
Re: Minimum quench ? [Re: RemCharger] #1361041
12/31/12 01:36 PM
12/31/12 01:36 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Guess where the .001" safety clearance you should have had went to?
It's deducted from your top ring land height, if you're lucky.
Boffin Emeritus
Re: Minimum quench ? [Re: polyspheric] #1361042
12/31/12 08:06 PM
12/31/12 08:06 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Depends on the piston type, cylinder clearance, intended rpm and rod type and quality. I'm running .035" on a small block with KB hypereutectic pistons and about .0025" clearance on the skirts. Runs great. I wouldn't be afraid of .030" on that one either. But you start opening up the bore and using forged pistons, you'll want more clearance because of piston rock and growth. I suggest shooting for zero deck and running the quench at whatever your gasket thickness is. On a Fel-Pro it'll typically be .039".
Re: Minimum quench ? [Re: RemCharger] #1361043
01/01/13 01:35 PM
01/01/13 01:35 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Yerp, I place marks on my pistons just for this. Run it close as I dare. Then pull the heads and see if I can go some more. Once I know I continue to run that. If I suddenly start seeing marks with the borescope I know there is something wrong.
What you can get away with depends on bore, piston to wall, rods, and what makes you nervous.
