Re: 70 RR airgrabber underdash solenoid?
[Re: JMCFAN]
#1360810
12/29/12 05:01 PM
12/29/12 05:01 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
This may help, 70 is the same.. It mounts on the top of the bottom flange of the dash below the switch... The screw goes in from the bottom though an oversized hole & into the hole on the solenoid bracket..
[Re: 1_WILD_RT]
#1360814
12/30/12 06:25 PM
12/30/12 06:25 PM
Posts: 1,730 elyria, ohio
72gtx4speed
elyria, ohio
replacement solenoids are available from BE&A parts and probably other vendors.
clem
when i grow up i want to be just like sunroofgtx, god please don't let me grow up.
[Re: 72gtx4speed]
#1360815
12/30/12 07:28 PM
12/30/12 07:28 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
clem
Yes, they are, as I mentioned in my earlier post
"replacements aren't cheap & the only thing that use to be available was either used or NOS.. Used you don't know if the replacement is any better than what you have, NOS could be bad to but it surely won't be cheap... Eliminating the solenoid the system works but the scoop doesn't close immediately when you shut the key off, "
They are now reproduced but they still aren't cheap...
http://www.beaparts.com/item_detail.aspx?id=990
I'm glad they are available but I'm also glad I don't need one..
Edited... I meant to type now but instead typed not... definitely changed the meaning of the post...
[Re: 72gtx4speed]
#1360818
01/06/13 09:52 PM
01/06/13 09:52 PM
Posts: 959 Chicago
PurpleBeeper
Chicago
clem
OMG! I bought my car in 1983 and it came with 13 boxes full of parts. I have this air grabber solenoid, but could never figure out what it was, what it did, etc.
Does anyone have a picture of exactly where it goes?
You learn something every day
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: 1970A13]
#1360819
01/06/13 10:20 PM
01/06/13 10:20 PM
Posts: 1,573 Rockford, IL.
Ruppman
Rockford, IL.
Correct me if i'm wrong but i thought the solenoid held the air grabber open if it was open and the key turned off,not bleed off the air?
me too, I had one of these years ago and I remember putting power to it and it would flow air through the 2 ports, release the juice and it would stop air flow. I don't remember any other vents or ports to bleed air off other than the 2 which hook to the hoses. Besides, you don't need to bleed the vacuum off with the engine off because the engine vacuum holds the AG open. Once the engine is off, intake vacuum goes away and the spring on the AG mechanism would close the scoop. Been a long time since I played around with an AG. $175 isn't too bad if you need one. I used to sell them in the early/mid 90's for $75 cause even then, they were hard to find. Anyway, best musclecar hood ever! IMO
mark
