Re: Dakota axle shaft removal question
[Re: buildanother]
#1360634
12/29/12 03:10 PM
12/29/12 03:10 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
And when you slide the axle out realize the axle shaft is a wearing part of the wheel bearing & it is commonly worn causing the axle seal to leak.... Look for a 3/4" wide groove worn into the bearing surface....
[Re: 1_WILD_RT]
#1360635
12/29/12 03:30 PM
12/29/12 03:30 PM
Posts: 13,610 md
mopars4ever
md
9 1/4 with noisy pinion bearings by chance?
should be a 8 3/8 (8 1/4) in V6 Dakota
[Re: mopars4ever]
#1360636
12/29/12 03:37 PM
12/29/12 03:37 PM
moparpollack
Lil Herman
Lil Herman
85086
Don't get the spider gears misaligned or it can be fun getting them aligned again. DAMHIK!
[Re: mopars4ever]
#1360640
12/30/12 08:53 AM
12/30/12 08:53 AM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
We did quite a few at work.The axles do wear and the bearing fix usually works well.Be careful taking the bolt/pin out.they will snap pretty easy.SnapOn makes a tool to remove them if they break.Ive had the spiders slip out.Not real hard to get them in as long as the shims dont get moved from side to side.Rocky
Chrysler Firepower
