Re: Front or Rear Caliper Mount?? [Re: 440PURSUIT] #1359847
12/30/12 10:36 AM
12/30/12 10:36 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Did a bot more research...Will check my Caliper Piston size. I assume they may be the smaller 74 Dart Calipers.
I see 78 Diplomat is about .10" larger.
Any one know the application of the smaller Rear wheel cylinder?
you're doing it wrong... (on the rear cylinders)
when increasing brake pressures/clamping loads for better braking, you want BIGGER caliper pistons/wheel cylinders, and SMALLER master cylinders.
**Photobucket sucks**
Re: Front or Rear Caliper Mount?? [Re: 440PURSUIT] #1359848
12/30/12 10:36 AM
12/30/12 10:36 AM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
Mid '70's pick up trucks generally used a 7/8 in. wheel cylinder instead of the more common 15/16 in. one found on cars. That's how I ordered mine.
Re: Front or Rear Caliper Mount?? [Re: Stanton] #1359849
12/30/12 11:29 AM
12/30/12 11:29 AM
Forth Worth, Texas, USA
TheRamMan Offline
TheRamMan  Offline
the 15/16 disc master is the best( 1707) 4 bolt there is....super rare now due to wonderful expert advice and articles...no 2 bolt conversion,no master blocks..no adjustable brake rods..that are never long enough for good thread engagement..esp on e body
and it is era correct, AND LOOKS RIGHT
Re: Front or Rear Caliper Mount?? [Re: TheRamMan] #1359850
12/30/12 02:12 PM
12/30/12 02:12 PM
DC, MD Suburbs
440PURSUIT Offline OP
DC, MD Suburbs
70 Cuda- I had 15/16 on rear. I found I had the 74 Dart 2.6" Piston Caplier on front.
I am swapping to the smaller MC now and ordered 2.75 Dippy Calipers.
Looking forward to the improvement.
Will swap pads when Calipers arrive. $23 for a loaded pair. Wholesaler closeout from ROCK. Wonder what pads are included?????
C-
Re: Front or Rear Caliper Mount?? [Re: 440PURSUIT] #1359851
12/30/12 03:37 PM
12/30/12 03:37 PM
AndyF Offline
AndyF  Offline
You'll see a 12% increase in brake force by going with the 2.75 inch caliper. That might be enough to fix the issue right there. If not, swap to a smaller bore size
MC and test it again. Stepping up to the larger 11.75 inch rotors would also be a good way to increase front brake force.
(I covered a lot of this topic in my B-body book.)
Re: Front or Rear Caliper Mount?? [Re: AndyF] #1359852
12/30/12 04:31 PM
12/30/12 04:31 PM
DC, MD Suburbs
DC, MD Suburbs
Andy, thanks for insight.
Found the smaller MC at Advance last night and swapped in out. Loosened the rear shoes a bit while at it.
Went out and warmed up existing pads. Not much difference.
Tested prop valve and started to get bias with valve all the way out. I can notice the front begin to engage now as I get a bit of nose down went applying brakes at speed.
Once the brakes seemed as good as they'd get I did a few panic stops (15-20mph) and still get rear lock up.
Not as severe now, though.
Will wait for loaded Diplomat Calipers to arrive.
Any pad recommendation for those? May need to source a better pad.
Re: Front or Rear Caliper Mount?? [Re: 440PURSUIT] #1359853
01/02/13 10:03 PM
01/02/13 10:03 PM
DC, MD Suburbs
DC, MD Suburbs
I read up on Feets brake math.
I have calculated the Pedal Ratio to be 4.8.
The 65 Coronet has a 12" long pedal and the pushrod bolt hole 2.5" down from pivot.
With the existing setup 15/16 MC and 2.6 Calipers, I am only generating 695 lbs of line pressure.
So....If I redrill a hole at 1.5" I will increase the pressure to 1157.
Is this recommended?
This is a 65 Coronet and I just read that 65 and back B bodies have different pedals. There is also a hole lower than the one I'm using at 1 7/8" lower.
Does any one know if this is a Power or Manual Brake Pedal?
The car was converted to a 4 speed before I got it. I am thinking a Power brake pedal was used.
Thoughts?
Re: Front or Rear Caliper Mount?? [Re: 440PURSUIT] #1359854
01/03/13 06:29 PM
01/03/13 06:29 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Drilling the hole higher in the pedal will make the pedal feel softer with more travel.
Play around with master cylinder sizes and see if some odd size will work with your ratio.
- Stu Harmon
Re: Front or Rear Caliper Mount?? [Re: feets] #1359855
01/03/13 07:47 PM
01/03/13 07:47 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Plus, redrilling another hole for a different pivot distance will place the pushrod at an up-angle (from the m/c, that is) which may create some issues with pushrod angularity and a thrust force on the lower half of the m/C bore. Don't know enough about pushrod lengths and so forth to know if this is something to be concerned about, but I'd sooner go with a smaller bore m/c and keep the correct pivot distance so the pushrod is still pushing somewhat straight down the bore rather than at an angle.
Re: Front or Rear Caliper Mount?? [Re: MoparMarq] #1359856
01/05/13 06:02 PM
01/05/13 06:02 PM
DC, MD Suburbs
DC, MD Suburbs
Drilled the hole higher before I saw Feets' Post. Pedal sucks! DOH!
Found a prop valve in my stuff and will try to hold off rear brakes.
Will see how this goes...
Re: Front or Rear Caliper Mount?? [Re: 440PURSUIT] #1359857
01/05/13 08:05 PM
01/05/13 08:05 PM
DC, MD Suburbs
DC, MD Suburbs
Swapped the Pushrod back to stock location. The pedal came back firm.
Went for a first ride with the prop/combo valve installed. This si the prop valve for a 70 the has 2 parts. I only used the lower part that is similar to drum brake distribution block.
Took the car for a test and found the prop/combo valve makes a difference. Backs don't lock regardless of existing "adjustable prop valve" position.
Actually, the fronts work better with the adjustable letting more fluid to rear since it cuts them off quicker.
I would consider that braking is now good. I will move to 7/8 rear wheel cylinders and hope for continued improvement.
Do you think that 2.75 Diplomat Calipers will help the cause???
Re: Front or Rear Caliper Mount?? [Re: 440PURSUIT] #1359858
01/06/13 12:24 PM
01/06/13 12:24 PM
yes more front bias & 76 A body (only) calipers are also 2.75" & the hose mounting location may or may not be in a better location for your app (or may be the same) I'm not sure but I'd have the parts guy pull both of em so you can eyeball em both when you go in to make your purchase
Re: Front or Rear Caliper Mount?? [Re: RapidRobert] #1359859
01/06/13 02:51 PM
01/06/13 02:51 PM
DC, MD Suburbs
DC, MD Suburbs
I installed the 2.75 later Diplomat calipers. The Hose Mount location comes in from the bottom. This seems better than the A Body 2.6's that feed from top.
We installed the calipers and new Ambulance Pads (Metallic). The car seems to brake fine, but won't put you through the windshield.
Coming down driveway I was able to lock up both front first.
All in all its safe now. I will still try some adjustment and the 7/8 rear wheel cylinders.
