Will front mount improve braking?
As said no, If you're going together ideally you'd want the calipers on the opposite side (front or rear) of the spindle as the hard line/hose mounting tab is so in other words the hose has to go horizontally behind/past the spindle to go from the caliper to reach the tab. If you are already up & running as is sounds like you are then if you have the right hose that does not bind/rub/kink from lock to lock or up/down in the suspensions' travel you're set. On my 65 Dart I mistakenly put the calipers on the rear & I needed to bend the front section of those particular hoses that is a hard line to get it all to clear. EDIT '74 A discs
