Measuring Pinion Bearing Preload??? #1359802
12/27/12 03:19 PM
12/27/12 03:19 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
The spec on a 489 case is 14-19 in/lbs with new bearings. I'll be using a solid spacer and shims. Is there a way I can measure this 14/19 in/lb without buying an expensive dial torque wrench?
Re: Measuring Pinion Bearing Preload??? [Re: mopowers] #1359803
12/27/12 03:55 PM
12/27/12 03:55 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
yes see if you can rent one ... it's rotating torque , you need a dial type to measure it properly .
Re: Measuring Pinion Bearing Preload??? [Re: JohnRR] #1359804
12/27/12 04:02 PM
12/27/12 04:02 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
I think find a place that will rent me one of those is going to be pretty hard.
Re: Measuring Pinion Bearing Preload??? [Re: mopowers] #1359805
12/27/12 05:48 PM
12/27/12 05:48 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
How about bolting an 18" bar to the pinion and using your kitchen scales. Should read 1lb on the scales.
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
Re: Measuring Pinion Bearing Preload??? [Re: Mick70RR] #1359806
12/27/12 07:30 PM
12/27/12 07:30 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
This is what I've always used.
http://www.amazon.com/2955-Torque-Wrench-0-60-Inch-Pounds/dp/B00004SQ3B
Sometimes you just have to break down and buy some tools. Sooner or later a hammer and crowbar just won't cut it.
Re: Measuring Pinion Bearing Preload??? [Re: 6PakBee] #1359807
12/28/12 01:05 PM
12/28/12 01:05 PM
Vitoria, Spain
Coke Offline
Coke  Offline
Vitoria, Spain
I used one of these too.I bought it on Ebay .
They are for bicycles,but do the job.
Re: Measuring Pinion Bearing Preload??? [Re: mopowers] #1359808
12/28/12 02:46 PM
12/28/12 02:46 PM
Cab_Burge Online work
Cab_Burge  Online Work
Snap On makes a 1/4 inch drive beam type torque wrench, works good
Re: Measuring Pinion Bearing Preload??? [Re: Cab_Burge] #1359809
12/28/12 10:45 PM
12/28/12 10:45 PM
Raleigh, NC
Meangreen68 Offline
Meangreen68  Offline
Raleigh, NC
I bought this CDI on Ebay for $40.
It has a memory-needle.
Keep a look out
Re: Measuring Pinion Bearing Preload??? [Re: Meangreen68] #1359810
12/28/12 10:56 PM
12/28/12 10:56 PM
Raleigh, NC
Meangreen68 Offline
Meangreen68  Offline
Raleigh, NC
Yep, the stars were aligned when I set up my 8-3/4.
I bought this brand-new 4-foot CDI 6004 (600lb) click-type for $115.
I drove onto Fort Bragg and bought it from a soldier's wife.
When she brought it out from her closet, it stood almost as tall as her!
Re: Measuring Pinion Bearing Preload??? [Re: Meangreen68] #1359811
12/28/12 11:13 PM
12/28/12 11:13 PM
Raleigh, NC
Meangreen68 Offline
Meangreen68  Offline
Raleigh, NC
...and I won't depress you any further for what I paid for this.
Anyone in the Raleigh, NC area that needs help setting-up, I'd be more than happy to oblige.
I sold my shop press a while back, so you'd need to have one
Re: Measuring Pinion Bearing Preload??? [Re: mopowers] #1359812
12/29/12 12:12 AM
12/29/12 12:12 AM
N
NITROUSN Offline
NITROUSN  Offline
N
I never checked with a torque wrench. I always went by feel. Not to seem like a smart a$$ but feel is all I went by. One you have set up 20 or so you will know what I feel.
Re: Measuring Pinion Bearing Preload??? [Re: Meangreen68] #1359813
12/29/12 04:37 AM
12/29/12 04:37 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Keep a look out
That's an awesome torque wrench, Wish I had one! But that memory needle won't help with bearing preload. Nice tool though. And great price!!
Re: Measuring Pinion Bearing Preload??? [Re: Mick70RR] #1359814
12/29/12 11:00 AM
12/29/12 11:00 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
...you said tongue-in-cheek. Right??
Re: Measuring Pinion Bearing Preload??? [Re: Commando1] #1359815
12/29/12 11:33 AM
12/29/12 11:33 AM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
No, I have a factory manual here showing preload being checked with spring scales. I've also seen factory tools that are just a calibrated bar that bolts to the pinion and a weight is slid along the bar until the pinion moves, then the torque is read off the bar. These days it's easier to just buy a suitable torque wrench but any method is better than just guessing.
Re: Measuring Pinion Bearing Preload??? [Re: NITROUSN] #1359816
12/29/12 11:52 AM
12/29/12 11:52 AM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
If you have adjusted tapered roller bearings you know when you have the preload correct.
Assemble it without the seal to get the real feel and have a good selection of shims.
Re: Measuring Pinion Bearing Preload??? [Re: mopowers] #1359817
12/29/12 01:05 PM
12/29/12 01:05 PM
Raleigh, NC
Meangreen68 Offline
Meangreen68  Offline
Raleigh, NC
I disagree, I turn the memory pointer against the main pointer when I get beyond the breakaway-torque.
And also, the memory pointer is independent of its own knob, which means the memory pointer "slips" once it makes contact with the main pointer of the torque wrench.
You can turn and turn the memory pointer's knob pushing the memory pointer against the main pointer, and the main pointer won't budge.
The tension on the memory pointer is very light and it can be turned against the main pointer at any time in the wrench's cycle.
Just my
Re: Measuring Pinion Bearing Preload??? [Re: Meangreen68] #1359818
12/29/12 03:14 PM
12/29/12 03:14 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Just my
Wow! That's awesome. Can I borrow it? HAHA!
Re: Measuring Pinion Bearing Preload??? [Re: mopowers] #1359819
12/29/12 09:55 PM
12/29/12 09:55 PM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
maybe im just weird but when it comes to a torque wrench I wont buy the cheapest thing out there...for 40 bucks how accurate is it really? I guess if your going to use it once and its your own stuff...but doing it professionally and have to guantee stuff...I guess Ill spend the money.
if you were local id let ya borrow mine or do it for ya, but ca isnt close to ct
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: Measuring Pinion Bearing Preload??? [Re: 6PakBee] #1359820
12/30/12 11:47 AM
12/30/12 11:47 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
That's all I use.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Measuring Pinion Bearing Preload??? [Re: GoodysGotaCuda] #1359821
12/30/12 04:29 PM
12/30/12 04:29 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I've always just bought the good tools I need for the job. It is amazing how many times you will use it. Buy the tool and keep it. A pawn shop is a good source. Bought all my Starrets there.
