Re: Big block head question here...
[Re: Moparnut426]
#1359317
12/26/12 04:04 PM
12/26/12 04:04 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
On factory heads the space changes but I use the .030 shims to correct any gaps/center on the valve stem tip. Edit: if you are looking for the big spacer size I can measure it for you.it is .700!I have my rockers on the kitchen table if you need more measurements. ![](/ubbthreads/images/graemlins/thumbs.gif)
