Rear tail light stud caps? #1359170
12/26/12 01:52 AM
12/26/12 01:52 AM
Surrey, British Columbia
TseTse Runner Offline OP
I have a '69 RR and read an article detailing that the studs on the rear tail light assemblies were covered with red plastic caps. Has anyone heard of these and if so where could these pieces be located? TseTse Runner.
Re: Rear tail light stud caps? [Re: TseTse Runner] #1359171
12/26/12 03:00 AM
12/26/12 03:00 AM
alaska
69 mayflower Offline
alaska
I got mine for my 69 Sport Satellite from Dixie Restorations.Fine people,great products,great service and they are sponsors here on Moparts.
1969 Plymouth Sport Satellite 383 1990 Dodge W150 plowtruck 318 2012 Dodge Ram 1500 4WD 5.7 HEMI 2012 Dodge Challenger R/T Classic Blackberry Pearl 5.7 HEMI MOPAR- WHAT ALL OTHER CARS WANT TO BE WHEN THEY GROW UP-
Re: Rear tail light stud caps? [Re: TseTse Runner] #1359172
12/26/12 03:05 AM
12/26/12 03:05 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Mine were; maybe 1/2" long with a flat end, IIRC. No idea if they're reproduced. Maybe they can be sourced from a company who lists them for another purpose.
I remember there was also a larger clear one that capped one of the studs that held the master cylinder mounting plate.
Re: Rear tail light stud caps? [Re: topside] #1359173
12/26/12 03:08 AM
12/26/12 03:08 AM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Re: Rear tail light stud caps? [Re: Scott Carl] #1359174
12/26/12 03:18 AM
12/26/12 03:18 AM
Missouri
Big_E Offline
Big_E  Offline
Missouri
Here is a pic of one in my car;
Re: Rear tail light stud caps? [Re: topside] #1359175
12/26/12 01:00 PM
12/26/12 01:00 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Found on most 1969 A and B bodies , can't say I've ever seen any red ones on E-bodies
Like mentioned there was also a translucent clear one on the firewall stud on some B body cars.
Re: Rear tail light stud caps? [Re: TseTse Runner] #1359176
12/27/12 01:55 AM
12/27/12 01:55 AM
cbusters Offline
cbusters  Offline
Not all had them, Some of the bezels had slightly shorter studs and the caps won't fit. I suspect a change in the design. While comparing the pieces I even found a couple bezels that had long barrels on the studs instead of the long bosses on the bezels to space the assemblies properly.
