I had a couple LA 509 cams I checked, and they actually have ramps not far from mech. cams. I think the ramps were something like .008-.010 camlift. This means you could in principle use these cams with solid lifters adjusting lash to the same, multiplied with the rocker ratio. I would adjust it hot, to be sure you are not way off. I ended up not using these cams for the intended use, as they would kill low end power. I have saved them for budget builds intending to use with solid lifters. I have no idea why they are made this way. I have checked other hydraulic cams, and I found more cams with small ramps in them. Maybe they need to cushion the lifters in the start of the lift?
