Lift vs Duration
#1358975
12/25/12 07:17 PM
12/25/12 07:17 PM
moparpollack
Lil Herman
Lil Herman
85086
Looked at a stocker cam and the class mandated a maximum lift but not duration. So stocker guys can you make decent power holding the valves open longer? ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
Re: Lift vs Duration
[Re: moparpollack]
#1358977
12/25/12 07:49 PM
12/25/12 07:49 PM
Posts: 5,898 Florida
Locomotion
Yes, but just like most other modifications, bigger isn't always better. One has to balance the amount of duration with engine size, compression, car weight, gears, etc. The cam companies tend to have a pretty good idea what's required. But you just have to get one of their "Stocker Specialists". Racers can also experiment one way or the other on their own.
It's always amazed me how fast Stockers can run within the limited rules. Of course there are a lot of things you can do that help and there are racers who "push the envelope", but when you consider the limits on lift and carb size, car weight, etc., it's still surprising.
i.e: Elephuntman, a member here, has a '70 340-6 Challenger T/A that ran 10.30's! I believe there have been some high compression '71 340's that have been 10.40's! But it takes a lot of time, research, testing & money. I can't afford to be that fast, but I'm content where I'm at.
[Re: Locomotion]
#1358978
12/25/12 08:23 PM
12/25/12 08:23 PM
moparpollack
Lil Herman
Lil Herman
85086
My buddy's son runs a 305 camaro and the cam was very odd looking. The guy who designed the cam was a national record holder. Supposedly the cam centerline was at 100-102 degrees. He suggested bringing the cam in as fast as possible. If possible sink the valves in the head so they don't hit the pistons. Just another way to make racing interesting and expensive. ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: moparpollack]
#1358979
12/25/12 08:31 PM
12/25/12 08:31 PM
Locomotion
Gotta watch that too because sinking valves can hurt air flow. Late '70's 360's come in "big cam" and "little cam" versions. Yet, NHRA has rated them at the same HP. I've heard from a couple of racers that they do run about the same and some actually prefer the smaller lift cam version! There are a few ways to change piston-to-valve clearance, including varying duration and advancing/retarding the cam. Depends what that particular engine likes.
[Re: DrCharles]
#1358983
12/25/12 10:17 PM
12/25/12 10:17 PM
Locomotion
The advertised duration was 352/380 degrees! Square lobes...
All the factories not only under-rated their engines for an advantage, they also "fudged" on some specs. Those numbers are way more than an engine could run on, but it gave racers and cam grinders a wide margin to work within for cam specs.
