4 piston calipers '''''' aftermarket replacement???? #1358901
12/25/12 03:26 PM
12/25/12 03:26 PM
Ont. Canada
10.90 Racer Offline OP
super street
super street
Ont. Canada
Is there an aftermarket replacement caliper that bolts in place of the original kelsey Hayes piece???
Re: 4 piston calipers '''''' aftermarket replacement???? [Re: 10.90 Racer] #1358902
12/25/12 04:11 PM
12/25/12 04:11 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Aren't those 4 pistons worth money?
2011 Drag Pak Challenger
Re: 4 piston calipers '''''' aftermarket replacement???? [Re: rickseeman] #1358903
12/25/12 04:25 PM
12/25/12 04:25 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Once the bores are shot it is cheaper to buy Aerospace brakes than to have them sleeved. The Aero brakes will save you 25 lbs. too. I tried to sell my complete 1972 setup at swap meets and never got an offer.
Re: 4 piston calipers '''''' aftermarket replacement???? [Re: cgall] #1358904
12/25/12 05:13 PM
12/25/12 05:13 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i recently upgraded to these 2 pot Bendix calipers & the bigger 13 1/2 " discs. my car stops soooooo much better now.
Re: 4 piston calipers '''''' aftermarket replacement???? [Re: 10.90 Racer] #1358905
12/25/12 08:32 PM
12/25/12 08:32 PM
Stuart FL
mercman1 Offline
mercman1  Offline
Stuart FL
Go to AREngineering .com. I used their adapter to swap over to Wilwoods. lighter and no valving adjustments. They have a std adapter or one that lets you also step up to the larger 13 inch cordoba rotor. Everything fit like a glove and the car (69GTX) stops awesome. PS did this 13 years ago and one of the best upgrages i've done to car.
Re: 4 piston calipers '''''' aftermarket replacement???? [Re: 10.90 Racer] #1358906
12/26/12 02:59 PM
12/26/12 02:59 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Check SSBC , I think they have an alum version that does .
