1971 GTX vibration issue "UPDATED PROBLEM SOLVED" #1358272
12/24/12 01:24 AM
12/24/12 01:24 AM
MI
AfterHoursResto Offline OP
MI
I just finished a rotisserie restoration on a 1971 GTX 440 auto 8 ¾ with a 323 posi. I am experiencing a on and off type vibration with begins at 40mph - 65mph. It may continue past 65 but that is as fast as I have driven the car since completed.
I have placed the trans in N while rolling down the road and the vibration continues even though the engine drops down to an idle.
I am running tapered bearings in the rear axels set at .010 .012. The bushing was replaced in the tail shaft of the trans during its overhaul. The drive shaft is brand new and I also tried to but the old shaft in and it did not make a difference.
The center section is a 489 case and was rebuilt using the original ring and pinion.
Everything is brand new or rebuilt on this car. It was restored to factory specs with no performance modifications. I am stumped.
Any input would be appreciated.
Roman Sobilo
Re: 1971 GTX vibration issue [Re: AfterHoursResto] #1358273
12/24/12 01:27 AM
12/24/12 01:27 AM
central P.A.
HEMIDOG 70 Offline
HEMIDOG 70  Offline
central P.A.
Tire balance?
Re: 1971 GTX vibration issue [Re: AfterHoursResto] #1358274
12/24/12 01:33 AM
12/24/12 01:33 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Also,you'll need to check the driveline angles and see where you're at...From here it's going to be a process of elimination...Start with the easy stuff...You've already taken the first step...No change in the vibration throwing the car in neutral is the first step...And I'm assuming there's no vibration in park... So it's not an engine balance issue..
Re: 1971 GTX vibration issue [Re: AfterHoursResto] #1358275
12/24/12 02:02 AM
12/24/12 02:02 AM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
on a 71b body
there is a weight that bolts to the floor above the driveshaft.
it is there to help driveshaft vibration.
is that weight missing?
i can get you a pic of it,
if you need to see what it looks like.
Re: 1971 GTX vibration issue [Re: AfterHoursResto] #1358276
12/24/12 02:29 AM
12/24/12 02:29 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Can you load the suspension on jackstands and run the car???
Re: 1971 GTX vibration issue [Re: RSNOMO] #1358277
12/24/12 02:50 AM
12/24/12 02:50 AM
MI
MI
I have tried two sets of tires. A brand new set of G 60's and the old set of radios the car came with and there was no change.
The driveline angle is at 2.5.
Thereis no wieght on the tailshaft or floor board. Would like to see a pictures of one!
Roman Sobilo
Re: 1971 GTX vibration issue [Re: AfterHoursResto] #1358278
12/24/12 03:58 AM
12/24/12 03:58 AM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
Could it be a bad u joint? I had the very thing happen last spring and it was a bad u joint. Also I thought pinion angle was suppose to range between 2.5-5.5 nose of diff down.
Mike
1969 Dodge Dart Swinger
Re: 1971 GTX vibration issue [Re: flypaper] #1358279
12/24/12 09:50 AM
12/24/12 09:50 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
on a 71b body
could you take a pic? I'm in the middle of putting my 71 runner back together and I haven't seen or heard of this weight?
Re: 1971 GTX vibration issue [Re: dangina] #1358280
12/24/12 10:10 AM
12/24/12 10:10 AM
Alabama
BigMoneyLewis Offline
Alabama
My first thought would be a wheel out of balance . I know you said you tried two sets of tires , but are you still using the same wheels, if so have they been balanced on a machine ?
My second guess would be a driveshaft out of balance .
Greg
gregward@mchsi.com phone 256-852-0955
Re: 1971 GTX vibration issue [Re: BigMoneyLewis] #1358281
12/24/12 11:34 AM
12/24/12 11:34 AM
I know you changed shafts but that'd be my guess, shaft or ujoints. How much freeplay does the shaft have into the trans? Want ~3/4" with the common aftermarket flat extension housing seal. I had too much & had a similar vibration that came & went. The correct slightly longer shaft took care of it. Holler how it goes
Re: 1971 GTX vibration issue [Re: dangina] #1358282
12/24/12 11:36 AM
12/24/12 11:36 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
on a 71b body
The weight was not used on 71/2 HP cars. Just LP cars. It mounts in the top of the tunnel right at the seam between the rear footwell and the under rear seat pans. Has a plate with 3 studs welded to the floor and the weight mounts to the suds under the pans.
I guess I don't have pics but can get some.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 1971 GTX vibration issue [Re: moparmarks] #1358283
12/24/12 11:53 AM
12/24/12 11:53 AM
MI
MI
Good suggestions everyone! Thanks.
Yes, the tires are mounted on two sets of rims. One set is about a year old and the other are brand new. So I don’t think it is the rims or tires.
Both shafts I tried have new u joints.
However, I do have more than ¾ sticking out of the tail shaft. Maybe someone swapped drive shafts out before I got my hands on the car.
Does anyone have the correct dimensions for a stock factory driveshaft (71 GTX 440 auto 8 ¾)?
Roman Sobilo
Re: 1971 GTX vibration issue [Re: AfterHoursResto] #1358284
12/24/12 12:52 PM
12/24/12 12:52 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
Here's a pic of that weight, not a good one, but all the way at the top of the photo. I don't think it's that.
If you have eliminated tires and wheels, how about a bad axle, disc brake (rotor)? Can you put it on a lift and run it? This may show if it's front or rear. You can even test it without tires and wheels. How was it before resto? The 3/4 inch probably is not a problem (keep that in mind till later).
Re: 1971 GTX vibration issue [Re: DANA60] #1358285
12/24/12 01:02 PM
12/24/12 01:02 PM
Rittman Ohio
fourgearsavoy Online tonguue
fourgearsavoy  Online Tonguue
Rittman Ohio
I have seen brake drums out of balance causing your exact problem
Gus
64 Plymouth Savoy
Dana 60
Re: 1971 GTX vibration issue [Re: fourgearsavoy] #1358286
12/24/12 01:20 PM
12/24/12 01:20 PM
MI
MI
I am getting ready to lift the rear, take the tires off, then the drums and see what happens. I will let you guys know. Thanks
Roman Sobilo
Re: 1971 GTX vibration issue [Re: AfterHoursResto] #1358287
12/24/12 05:31 PM
12/24/12 05:31 PM
Rittman Ohio
Rittman Ohio
Just remember don't step on the brake pedal with the drums off
Gus
64 Plymouth Savoy
Dana 60
Re: 1971 GTX vibration issue [Re: fourgearsavoy] #1358288
12/25/12 11:44 AM
12/25/12 11:44 AM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
Yes, and be carefull not to put the car in reverse or park right away after run up. There is no way that the drivetrain will stop on it's own. It's important to make sure the drivshaft stops turning before dropping out of drive. Maybe even turn the car off before that
Re: 1971 GTX vibration issue [Re: DANA60] #1358289
12/25/12 12:03 PM
12/25/12 12:03 PM
With the drums off that's what I'd do, as you know it can still be turning a bit in neutral. Easy to get fooled since the car ain't moving your brain automatically thinks it's OK to move the selector to a different position. Yes you'd have to have alot more than 3/4" end play for that to be the problem like it was in my case & in diagnosing that problem I noticed that the yoke had to be engaged quite aways in on the output shaft spline till it felt solidly engaged which I thought was strange. I think that was because not all of the inside length of the yoke is splined & that distance varied from yoke to yoke. Holler how things go.
Re: 1971 GTX vibration issue [Re: RapidRobert] #1358290
12/26/12 06:28 PM
12/26/12 06:28 PM
moparmarks Offline
moparmarks  Offline
71 GTX 440/727/8.75 drive shaft is 50.75" center between joints.
Here is the non-HP weight and mounting bracket.
I've had/have upwards of 20 71/2B HP cars and none had this weight. I did just partout a 73 Charger 400HP car that has this weight as well as all my 71/3 non-HP cars.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 1971 GTX vibration issue [Re: moparmarks] #1358291
12/26/12 06:29 PM
12/26/12 06:29 PM
moparmarks Offline
moparmarks  Offline
Mounting bracket welded onto the pans.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
