Re: 308 bearing on a 4 speed - different sizes?
[Re: 4406bbl]
#2441614
01/27/18 05:22 PM
01/27/18 05:22 PM
Posts: 10,736 North Dakota
6PakBee
North Dakota
I think that motion bearing is a 308 sg10, you need 308 sg8, sg8s are no longer made, unless something has changed. And just when you think you have cut a fat hog in the butt......
[Re: 135sohc]
#2442364
01/28/18 06:40 PM
01/28/18 06:40 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Unless all you have is a 308 case there is no reason you can't use a 307 bearing case. I have built quite a few 307 bearing HEMI boxes and they are perfectly fine. Just because you can't find a 308 bearing at your local parts store doesn't mean they aren't available. I never go to a parts store for a bearing because they are limited to what applications they have in front of them. I buy the correct 308 bearing from Akron Bearing and they have them in stock. I run a 307 bearing HEMI box in my Savoy and it's working just fine. I would prefer a sealed bearing in my transmissions because the chunks of brass and metal floating around in the gear oil is the reason these bearing fail. My next transmission will probably have sealed bearings in it Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#2442382
01/28/18 07:02 PM
01/28/18 07:02 PM
Posts: 1,908 Nebraska
4406bbl
Nebraska
Unless all you have is a 308 case there is no reason you can't use a 307 bearing case. I have built quite a few 307 bearing HEMI boxes and they are perfectly fine. Just because you can't find a 308 bearing at your local parts store doesn't mean they aren't available. I never go to a parts store for a bearing because they are limited to what applications they have in front of them. I buy the correct 308 bearing from Akron Bearing and they have them in stock. I run a 307 bearing HEMI box in my Savoy and it's working just fine. I would prefer a sealed bearing in my transmissions because the chunks of brass and metal floating around in the gear oil is the reason these bearing fail. My next transmission will probably have sealed bearings in it Gus Thats good to know, will call them as I need 2 and my local has the incorrect 308. Thanks
[Re: fourgearsavoy]
#2443304
01/30/18 11:17 AM
01/30/18 11:17 AM
Posts: 356 NE
moparpoolman
NE
Unless all you have is a 308 case there is no reason you can't use a 307 bearing case. I have built quite a few 307 bearing HEMI boxes and they are perfectly fine. Just because you can't find a 308 bearing at your local parts store doesn't mean they aren't available. I never go to a parts store for a bearing because they are limited to what applications they have in front of them. I buy the correct 308 bearing from Akron Bearing and they have them in stock. I run a 307 bearing HEMI box in my Savoy and it's working just fine. I would prefer a sealed bearing in my transmissions because the chunks of brass and metal floating around in the gear oil is the reason these bearing fail. My next transmission will probably have sealed bearings in it Gus Which is better for a race application, 307 or 308 case? I've broke 3 A833's with the 308 so far, sheared all the teeth off third gear on the cluster all three times and they didn't have many miles on them so the bearings were not worn?
[Re: fourgearsavoy]
#2443306
01/30/18 11:26 AM
01/30/18 11:26 AM
6PakBee
North Dakota
...I buy the correct 308 bearing from Akron Bearing and they have them in stock.... I just finished an email exchange with Steve Kalgreen from Akron Bearing Co. I asked for a 308 SG8 bearing with the 0.825" race width and he had no idea what I was talking about.
[Re: moparpoolman]
#2443308
01/30/18 11:27 AM
01/30/18 11:27 AM
6PakBee
North Dakota
Which is better for a race application, 307 or 308 case? I've broke 3 A833's with the 308 so far, sheared all the teeth off third gear on the cluster all three times and they didn't have many miles on them so the bearings were not worn? Sounds like a shifter adjustment concern to me.
[Re: 6PakBee]
#2443864
01/31/18 02:25 AM
01/31/18 02:25 AM
4406bbl
Nebraska
...I buy the correct 308 bearing from Akron Bearing and they have them in stock.... I just finished an email exchange with Steve Kalgreen from Akron Bearing Co. I asked for a 308 SG8 bearing with the 0.825" race width and he had no idea what I was talking about. Same story here, my local only had 308l.
[Re: 6PakBee]
#2444235
01/31/18 09:13 PM
01/31/18 09:13 PM
fourgearsavoy
Rittman Ohio
...I buy the correct 308 bearing from Akron Bearing and they have them in stock.... I just finished an email exchange with Steve Kalgreen from Akron Bearing Co. I asked for a 308 SG8 bearing with the 0.825" race width and he had no idea what I was talking about. Last fall I walked in with the bearing in my hand and The girl behind the counter just whipped out her calipers and made some measurements and got me the correct bearing. Gus
[Re: 6PakBee]
#2444355
01/31/18 11:40 PM
01/31/18 11:40 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
Which is better for a race application, 307 or 308 case? I've broke 3 A833's with the 308 so far, sheared all the teeth off third gear on the cluster all three times and they didn't have many miles on them so the bearings were not worn? Sounds like a shifter adjustment concern to me. Third gear is the one to go when you have traction, weight and power. If he's driving it hard and hooking, 3rd gear will have a short life.
[Re: dragon slayer]
#2919738
05/07/21 06:07 PM
05/07/21 06:07 PM
Posts: 5,898 ohio
ruderunner
ohio
What are the correct dimensions for this bearing?
ID OD WIDTH?
Perhaps most importantly, distance from the snap ring to the surface that the input shaft mates to.
I'm thinking that with the right spacers or shims a standard 308 can work. Alternatively, I might be able to source a suitable bearing, we deal with lots of them at work, including some proprietary ones.
Angry white pureblood male
[Re: dragon slayer]
#2920512
05/09/21 07:06 PM
05/09/21 07:06 PM
Posts: 5,898 ohio
ruderunner
ohio
Ok, that's a very confusing way to answer a simple question. So for clarification...
ID. 1.378
Width. 827
OD, whatever is standard for a 308 bearing?
Does anyone have a dimension for the inboard race to outboard snap ring dimension?
[Re: ruderunner]
#2920554
05/09/21 08:54 PM
05/09/21 08:54 PM
Posts: 1,329 VA
dragon slayer
VA
OD is 90mm. For SG, Go look it up it is in the 307 or 308 spec from MRC or SKF. I was just trying to clarify why it is a special 308. It matches the 307 except for OD. In my opinion this is not something you want to start shimming. Use the correct bearing and selective snap ring.
