65 dart gt #1357844
12/23/12 07:46 PM
12/23/12 07:46 PM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
just wondering if any one makes bigblock headers for the early a's yet or what works thanks.
Re: 65 dart gt [Re: buck440] #1357845
12/24/12 08:58 AM
12/24/12 08:58 AM
gregsdart Offline
gregsdart  Offline
Buck, I started with a 440 block in my 65 Dart and there simply isn't enough room to put that combo together with underchassis headers. The best thing you can do is to start with a low deck/stock location exhaust port head combo to keep from having to cut the passenger side shock tower for tube clearance. On the 440 the manifold studs were right up against the shock tower on the center two ports. I have never tried to fit the B/stock port combo so I don't know if it will have enough room, But even if it does the headers would be restrictive at the center two ports on the pass side for sure.
My solution was fenderwell headers built by me. I can offer this from experience. First, I still needed to cut the pass side shock tower and move the chock stud mount out. For turning radius, they need to go four wide when going down behind the front tires for the turning radius issue. With what TTI or any others charge (and none fit the early A BB combo anyway)it may be in your best interest to have them custom built for your application. Someone else may chime in on fenderwells built for B bodys that may fit, but there will be big compromises most likely somewhere.
Another option might be to go with a Mustang II front end. An altercation type front is another option, but spendy.
The Mustang II may seem expensive, but you wind up with good disc brakes and less weight in the deal as well. Check the street rod Mustang II venders for custom applications like yours. The M II would seriously open up the engine bay and allow the use of many off the shelf headers, but still may require notching the trans cross member for both sides. Some of the early As had only one side designed for exhaust to clear. Hope this helps.
Re: 65 dart gt [Re: gregsdart] #1357846
12/24/12 12:00 PM
12/24/12 12:00 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Man.....I have a small block with large-ish tubes ( 1 7/8" ) and that was interesting even with the AlterKtion.
Still have one tube outside the frame rails , and the primaries are a little longer than optimum.
That was with removing the shock towers and a good bit of inner fender.
I would have been hating life if I tried to go with a big block.
I am not saying it can't be done , but it will be snug and either time consuming or expensive.......or both.
Re: 65 dart gt [Re: tubtar] #1357847
12/26/12 12:13 AM
12/26/12 12:13 AM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
thanks guy'sit can be done with hp manifold's so i hear ?
Re: 65 dart gt [Re: buck440] #1357848
12/26/12 12:32 AM
12/26/12 12:32 AM
Middletown, Ohio
Joes66dart Offline
Joes66dart  Offline
Middletown, Ohio
We put a 440 in our 66dart. I used fenderwells for a BB a body and cut up some tubes to make them work. Im no longer using them and might sell them if your interested.
Re: 65 dart gt [Re: Joes66dart] #1357849
12/26/12 03:12 AM
12/26/12 03:12 AM
Mcallen, TX
SB449VALIANT Offline
Mcallen, TX
1 7/8 to 2" 65 with a 449 sb mopar, i did try to build them 2" all the way but i just coludnt find the 2" donut, at that time.. But you can custom make your own....
[image]http://https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-ash4/403796_10151444958455297_945463031_n.jpg?dl=1[/image]
Re: 65 dart gt [Re: SB449VALIANT] #1357850
12/26/12 03:18 AM
12/26/12 03:18 AM
Mcallen, TX
Mcallen, TX
2
Re: 65 dart gt [Re: SB449VALIANT] #1357851
12/26/12 03:19 AM
12/26/12 03:19 AM
Mcallen, TX
Mcallen, TX
3
Re: 65 dart gt [Re: SB449VALIANT] #1357852
12/26/12 03:20 AM
12/26/12 03:20 AM
Mcallen, TX
Mcallen, TX
Last
Re: 65 dart gt [Re: buck440] #1357853
12/26/12 05:02 AM
12/26/12 05:02 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I would guess you could on the passenger side, but the steering shaft is in the way on the driver's side. I don't think the factory manifolds for the '67-'69 cars will come close.
Re: 65 dart gt [Re: Joes66dart] #1357854
12/26/12 08:37 AM
12/26/12 08:37 AM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
pm sent.
Re: 65 dart gt [Re: buck440] #1357855
12/26/12 08:51 AM
12/26/12 08:51 AM
gregsdart Offline
gregsdart  Offline
This would be a great time to take photos and share what mods were done to make them fit, then archive it. Care to do that? If you post the pics and info, we can get a mod to take care of the rest.
Re: 65 dart gt [Re: SB449VALIANT] #1357856
12/26/12 09:05 AM
12/26/12 09:05 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
SB449VALIANT , all I can say is well played , Sir.
I was probably overly concerned with length to the first bend , but should get some pics of the finished product for show and tell.
You did a more than pretty fair job on those.
Re: 65 dart gt [Re: tubtar] #1357857
12/26/12 09:33 AM
12/26/12 09:33 AM
East Coast
A/MP Offline
A/MP  Offline
East Coast
What everyone has said is true. A stepped set 1 7/8 to 2" can help. Try to look at a set of headman race tubes for th 64-66 A body SB. It is a tight fit with some dinging but it might give you a better map for snaking those pipes. Not sure for your HP application, a 1 3/4 to 1 7/8 to 2" might be the ticket.I've seen this in stock eliminator cars and we all know how fast they can be.
Re: 65 dart gt [Re: A/MP] #1357858
12/26/12 09:37 AM
12/26/12 09:37 AM
Finland
mafo Offline
mafo  Offline
Finland
Race car only, 1 7/8 -2- 2 1/8
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: 65 dart gt [Re: mafo] #1357859
12/26/12 09:41 AM
12/26/12 09:41 AM
Finland
mafo Offline
mafo  Offline
Finland
In car
Re: 65 dart gt [Re: mafo] #1357860
12/26/12 09:43 AM
12/26/12 09:43 AM
Finland
mafo Offline
mafo  Offline
Finland
top
Re: 65 dart gt [Re: tubtar] #1357861
12/26/12 12:31 PM
12/26/12 12:31 PM
Mcallen, TX
Mcallen, TX
Re: 65 dart gt [Re: mafo] #1357862
12/26/12 12:35 PM
12/26/12 12:35 PM
Mcallen, TX
Mcallen, TX
Re: 65 dart gt [Re: SB449VALIANT] #1357863
12/26/12 05:14 PM
12/26/12 05:14 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
THe OP wanted big block headers
