2001 300m won't stay running #1357729
12/23/12 04:44 PM
12/23/12 04:44 PM
Sturgis S.D.
tripleblackcuda Offline OP
Sturgis S.D.
My 2001 Chrysler 300m will not stay running unless I give it some throttle, let off it dies. In order to start I have to give it a slight amount of throttle as well. Any ideas? It is a 3.5 engine.
Re: 2001 300m won't stay running [Re: tripleblackcuda] #1357730
12/23/12 05:03 PM
12/23/12 05:03 PM
SK,Canada
gregsrt Offline
gregsrt  Offline
SK,Canada
Could be a throttle position sensor or it could be a weak battery. The TPS must read a certain amount of voltage in order to work correctly. Check the battery first .
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry. Thomas Jefferson
Re: 2001 300m won't stay running [Re: gregsrt] #1357731
12/23/12 07:11 PM
12/23/12 07:11 PM
Sturgis S.D.
Sturgis S.D.
Battery is ok, TPS then?
Re: 2001 300m won't stay running [Re: tripleblackcuda] #1357732
12/23/12 07:21 PM
12/23/12 07:21 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
I would start by cleaning the throttle body and Idle air sensor. Are there any codes? The IAS controls the idle when your foot is off the peddle.
Re: 2001 300m won't stay running [Re: T2R9] #1357733
12/23/12 07:26 PM
12/23/12 07:26 PM
Sturgis S.D.
Sturgis S.D.
I don't have a reader here. I will go and scan it and see if there is anything.
Re: 2001 300m won't stay running [Re: tripleblackcuda] #1357734
12/24/12 01:52 AM
12/24/12 01:52 AM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
check your air tube to the maf if it has one...been down that road!
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: 2001 300m won't stay running [Re: pnypwr] #1357735
12/24/12 02:27 AM
12/24/12 02:27 AM
Renton Washington
Triple Threat Offline
Renton Washington
IAC (idle air control)
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: 2001 300m won't stay running [Re: Triple Threat] #1357736
12/24/12 03:44 AM
12/24/12 03:44 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Is the Check Engine lite on ? 9 out of 10 times this is a dirty throttle body. Carbon builds up enough arond the throttle baldes and in the IAC (idle air contol) and it does not get enough air to idle. The IAC will make up for it but it cant do it fast enough so it stalls. The PCM is programed for a certain amout of steps on the IAC at certain temps. Now when you start the car if the idle is to low the PCM will run the IAC steps up and advance the timing some to try and hold an idle. But as I said it cant to it fast enough if the throttle body is dirty enough.
Thats what I see the most but I have had times when the IAC may be bad or the EGR valve may stick open at idle.
Generally the TPS will not cause that as the PCM has a programed idle speed if it doesn't get a reading from .5 to about 1 volt at idle. Most of the time a bad TPS acts like a bad acellerator pump in a carb and causes a hesitation. Also if the battery has gone dead or been drawn down to a low voltage the PCM can forget the idle IAC setting and has to relearn it which takes some time and of course it wont hold and idle when its relearning the IAC steps. Ron
Re: 2001 300m won't stay running [Re: 383man] #1357737
12/24/12 08:11 AM
12/24/12 08:11 AM
Ohio
Todd Offline
Todd  Offline
Ohio
x2
Great job of explaining that I was going to but didn't want to have to do all that typing.
Re: 2001 300m won't stay running [Re: 383man] #1357738
12/24/12 11:59 AM
12/24/12 11:59 AM
A tad North of Indy
Blown71X Offline
super gas
Blown71X  Offline
super gas
A tad North of Indy
What He said
Before you do anything....reset the PCM and let it relearn the IAC counts
Discon the battery for a minute or so, reconnect and turn the key to run (DO NOT just get in and start it) count to 10 and then start it, this allows the PCM to run the IAC pintle in and learn where it is.
Mopars are terrible for losing the IAC count with a marginal battery or poor cable connections, The PCM goes mental when the voltage hits 9 volts, That is very easy to do with a marginal batt/cable and still have it start.
This is why you will see/hear of so many that have idle issues after a jump start.
It still amazes me how many get towed in for silly stuff like this.
Edit...Only stepper motor(4 wire) IAC`s which you have are susceptible to this, newer stuff with A linear motor will not do it.
Rick
Blown71X V2.0 under construction 71 Cuda 383 4-SPD (maybe for sale) 2010 Challenger B5 Classic
Re: 2001 300m won't stay running [Re: Blown71X] #1357739
12/24/12 04:02 PM
12/24/12 04:02 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Rick
How is going Rick ? I forgot about turning the key on for 10 seconds as I also did that. But I have been out of the buiness for 2 years and am starting to forget some things. I remeber the two wire Linear IAC's and I thougt they started about 2006 but I may be wrong. I also remember some of them went to a hall efect TPS around that time. Ron
Re: 2001 300m won't stay running **UPDATED** [Re: Todd] #1357740
12/30/12 03:35 PM
12/30/12 03:35 PM
Sturgis S.D.
Sturgis S.D.
Thanks for all the help guys, I was able to clean the throttle body and sensors with Berryman carb and choke cleaner. My 300 is running great now! I also poured a bottle of cleaner in the tank for insurance. Thanks again.
Re: 2001 300m won't stay running **UPDATED** [Re: tripleblackcuda] #1357741
12/30/12 03:41 PM
12/30/12 03:41 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
Re: 2001 300m won't stay running **UPDATED** [Re: T2R9] #1357742
12/31/12 01:18 AM
12/31/12 01:18 AM
Sturgis S.D.
Sturgis S.D.
I forgot to mention I sprayed almost a full bottle of B-12 Cleaner down the top vacuum port. Man did it smoke and stink, but it runs better!
