rod side clearance,proper torquing,pinion angle,which , #1357529
12/23/12 03:46 AM
12/23/12 03:46 AM
gregsdart Offline OP
way does the TP come off the roll.
Just counting the topics we chew on back and forth. Trying to kill time till Santa beings me my toys!!
Re: rod side clearance,proper torquing,pinion angle,which , [Re: gregsdart] #1357530
12/23/12 11:43 AM
12/23/12 11:43 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
you left out rod length!
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: rod side clearance,proper torquing,pinion angle,which , [Re: gregsdart] #1357531
12/23/12 12:31 PM
12/23/12 12:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Since your bored I'll let you come over and sand on
my Rampage... that'll take the boredom out of you... LOL
Re: rod side clearance,proper torquing,pinion angle,which , [Re: gregsdart] #1357532
12/23/12 12:33 PM
12/23/12 12:33 PM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
You forgot how much power can an 8 3/4 take...
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: rod side clearance,proper torquing,pinion angle,which , [Re: yella71] #1357533
12/23/12 12:45 PM
12/23/12 12:45 PM
Tucson, Arizona
MRMOPAR Offline
MRMOPAR  Offline
Tucson, Arizona
not to mention ... weight difference between "axle A" and "axle B" ... K frames ... guess my HP!!
68 RR 528" INDY MAXX 07 2500 CTD Southwest International Raceway - IHRA - Tucson, AZ
Re: rod side clearance,proper torquing,pinion angle,which , [Re: MRMOPAR] #1357534
12/23/12 12:51 PM
12/23/12 12:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Or what cam is best
Re: rod side clearance,proper torquing,pinion angle,which , [Re: MR_P_BODY] #1357535
12/23/12 01:13 PM
12/23/12 01:13 PM
still waiting on 684
K
Kiner Offline
Kiner  Offline
K
Cal Tracs
Re: rod side clearance,proper torquing,pinion angle,which , [Re: gregsdart] #1357536
12/23/12 01:43 PM
12/23/12 01:43 PM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
What about "pop-up" pistons ???
3/4 cams ?
Re: rod side clearance,proper torquing,pinion angle,which , [Re: Kiner] #1357537
12/23/12 01:43 PM
12/23/12 01:43 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
When the parts come flying out of your 10 or 11 second small block at 8200rpm do you prefer paper or plastic bags for picking up the pieces?
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: rod side clearance,proper torquing,pinion angle,which , [Re: pittsburghracer] #1357538
12/23/12 01:49 PM
12/23/12 01:49 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
What will be the lift with 1.6 rockers...
Do I need a high volume oil pump
Re: rod side clearance,proper torquing,pinion angle,which , [Re: BSB67] #1357539
12/23/12 01:51 PM
12/23/12 01:51 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
How much horsepower will a 23 spline tranny take and what clutch should I use
Gus
64 Plymouth Savoy
Dana 60
Re: rod side clearance,proper torquing,pinion angle,which , [Re: fourgearsavoy] #1357540
12/23/12 01:56 PM
12/23/12 01:56 PM
We got a great list going! Keep them coming! Even the guys I don't agree with!
Re: rod side clearance,proper torquing,pinion angle,which , [Re: MR_P_BODY] #1357541
12/23/12 01:57 PM
12/23/12 01:57 PM
It would be worth the education!
Re: rod side clearance,proper torquing,pinion angle,which , [Re: gregsdart] #1357542
12/23/12 02:09 PM
12/23/12 02:09 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
who put the BANG in the WALLA WALLA BING BANG?thats what we should all be askin!!!!!
Re: rod side clearance,proper torquing,pinion angle,which , [Re: gregsdart] #1357543
12/23/12 02:12 PM
12/23/12 02:12 PM
New York
polyspheric Offline
polyspheric  Offline
New York
We need a "Read the bleeping manual!" section, which automatically catches all "How big is my motor when bored .60 over?"
Boffin Emeritus
Re: rod side clearance,proper torquing,pinion angle,which , [Re: polyspheric] #1357544
12/23/12 02:16 PM
12/23/12 02:16 PM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
ORE how many Berri-Crabs go up-in-flames !
Re: rod side clearance,proper torquing,pinion angle,which , [Re: dOc …] #1357545
12/23/12 02:37 PM
12/23/12 02:37 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
727 or Pukeglide?
Re: rod side clearance,proper torquing,pinion angle,which , [Re: slantzilla] #1357546
12/23/12 03:21 PM
12/23/12 03:21 PM
Az
Crizila Offline
Crizila  Offline
Az
What size tires will fit in my fender wells? What would cause this noise?
Fastest 300
Re: rod side clearance,proper torquing,pinion angle,which , [Re: Crizila] #1357547
12/23/12 03:29 PM
12/23/12 03:29 PM
Florida STAYcation
dOc … Offline
dOc …  Offline
Florida STAYcation
BTW ...what IS the proper TORQUE for the oil-pan and water pump BOLTS ?
Re: rod side clearance,proper torquing,pinion angle,which , [Re: gregsdart] #1357548
12/23/12 03:34 PM
12/23/12 03:34 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
So guys....I got $2500.00 burning a hole in my pocket, and I want to build a 800 HP 500" BB stroker....what parts would you use" ? How fast will it go in my 4200# c body ? " Id like to run low 9's".
RIP Monte Smith
