Re: SB motor plate for electric water pump [Re: Bignick] #1357506
04/03/13 01:31 AM
04/03/13 01:31 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
here's our "home brew" approach...
Re: SB motor plate for electric water pump [Re: J_BODY] #1357507
04/11/13 03:00 AM
04/11/13 03:00 AM
Louisiana
Bignick Offline
Bignick  Offline
Louisiana
Looks easy enough. And I will have to build that same deal if no one comes up with some nice machined parts. What alt. are you using?
70 Duster 422"eddy head smallblock, PTC built 904, PTC 8" conveter, Dana 60 4.56 gear
Re: SB motor plate for electric water pump [Re: AndyF] #1357508
04/11/13 11:47 AM
04/11/13 11:47 AM
ccarson Offline
ccarson  Offline
I'm installing a motor plate with an electric CSR pump, and was going to remove and machine flat the production housing so I wouldn't end up with
cavity behind the motor plate, is there any reason you wouldn't want to do this? its a 59 Deg W9 motor.
Re: SB motor plate for electric water pump [Re: Bignick] #1357509
04/11/13 04:08 PM
04/11/13 04:08 PM
AndyF Online content OP
AndyF  Online Content OP
What about the low mount alt. kit for small block?
The low mount alternator kit is also available. All it takes is the strap since the mount and adjustment point are built into the motor plate.
Re: SB motor plate for electric water pump [Re: ccarson] #1357510
04/11/13 04:10 PM
04/11/13 04:10 PM
Yes, you can do that. It is just a bit of a hassle and it probably doen't gain too much. But it saves about 1/2 of space so that is good.
You'll end up with the fuel pump boss sticking into the motor plate so then you have to machine that down, or make a hole in the plate.
Re: SB motor plate for electric water pump [Re: AndyF] #1357511
04/12/13 12:23 PM
04/12/13 12:23 PM
ccarson Offline
ccarson  Offline
i was going to machine the fuel pump boss down also and Tig a cover over it just to get it out of the way This motor will never see a Mech Pump.
