half fill on street #1357275
12/22/12 08:21 PM
12/22/12 08:21 PM
Saskatchewan (SK)
79410aspenrt Offline OP
Saskatchewan (SK)
can i run my x block on the street with it half filled
not running a 1000 miles but 20-30 miles
Re: half fill on street [Re: 79410aspenrt] #1357276
12/22/12 08:47 PM
12/22/12 08:47 PM
so ca
mikesiron Offline
mikesiron  Offline
so ca
Yep I ran 3/4 fill on my round track car for yrs with no problem, should'nt be a problem with good cooling system.
Re: half fill on street [Re: 79410aspenrt] #1357277
12/22/12 10:30 PM
12/22/12 10:30 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
it's a strong block. why would u want to fill it for 20 miles of street use? oil temps will be higher on street use.
Re: half fill on street [Re: rickraw] #1357278
12/22/12 10:32 PM
12/22/12 10:32 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
maybe it is already filled.
It would be cooler in Canada. I ran a 3/4 filled on the street. Really needed an oil cooler but water temp was just fine.
Re: half fill on street [Re: Leon441] #1357279
12/22/12 10:49 PM
12/22/12 10:49 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Water temp will be just fine because it is not contacting as much area or carrying away as much heat, the area around the bottom of the bores will have little place for the heat to go and it will build heat in that part of the block but it is just iron so how cool does it have to be. If oil temp gets out of hand (it probably will) then run a good oil cooler then the top and bottom of the engine will be fine and the middle will be like a giant heat sink. I bet if you had a temp sensor mounted deep in the filled part of the block you would be supprised how hot it gets in there
