Re: taillights staying on 1971 Demon
[Re: tripleblackcuda]
#1357250
12/22/12 07:35 PM
12/22/12 07:35 PM
RapidRobert
The taillights are the small filaments in the 1157 bulbs & the brakes/turn signals/hazards all use the same large filament in that bulb. More info, which system is on/acting up right now & which filament is getting brighter?
#1357253
12/22/12 07:51 PM
12/22/12 07:51 PM
RapidRobert
Is that filament the thicker or the thinner one? (I forget which one is the taller). We're working with the running lights (only) with the headlight switch being pulled out (on) correct? The brake lights/flashers/turn signals are OFF?
[Re: Challenger 1]
#1357255
12/22/12 08:15 PM
12/22/12 08:15 PM
Posts: 27,471 So Cal
autoxcuda
So Cal
Pull the brake petal up with your hand and see if they go off.
And check the brake switch to pedal contact under the dash.
[Re: Challenger 1]
#1357256
12/22/12 08:19 PM
12/22/12 08:19 PM
Posts: 1,012 indiana
mcmopars
indiana
wouldnt that be brake light not tail light?
#1357261
12/23/12 11:23 PM
12/23/12 11:23 PM
RapidRobert
I'd go to the electrical pull apart connector behind the DR kick panel & jump fire to the running (tail) lights/the dr brake light/and the pass brake light & see if you're good in the rear. That'll direct you whether to work downstream or back up under the dash. www.mymopar.com will have the colors for you.
[Re: RapidRobert]
#1357262
12/24/12 12:41 AM
12/24/12 12:41 AM
Posts: 998 Sturgis S.D.
tripleblackcuda
Sturgis S.D.
Thanks for the help. I will do that tomorrow and see what I got.
