Rallye wheel cap refinishing #1356690
12/21/12 01:19 PM
12/21/12 01:19 PM
new york
lilmoose102 Offline OP
new york
I have a 70 roadrunner,15 inch rallye wheel,silver wheels with dark argent wheel caps.I want to refinish the wheel caps.Has anybody done this and how is that argent spray paint to work with?
Re: Rallye wheel cap refinishing [Re: lilmoose102] #1356691
12/21/12 01:43 PM
12/21/12 01:43 PM
JERSEY
RJS Online work
RJS  Online Work
JERSEY
On a 70 you'll want to use light argent.
I think totally auto is where I got mine in the past.
There product is great but the nozzles usually clog easy so they usually send extra nozzles.
I think one time I had to use an undercoating nozzle and back away from what I was spraying since the hole is much bigger.
Hope this helps
Re: Rallye wheel cap refinishing [Re: RJS] #1356692
12/21/12 08:05 PM
12/21/12 08:05 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
I used the Totally Auto light argent on my 70 centers and they came out great.
Re: Rallye wheel cap refinishing [Re: 5carguy] #1356693
12/22/12 10:13 AM
12/22/12 10:13 AM
Kentucky
dfsmopars Offline
dfsmopars  Offline
Kentucky
Here is a picture of the light argent from Totally Auto on caps I refinished.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: Rallye wheel cap refinishing [Re: lilmoose102] #1356694
12/22/12 10:55 AM
12/22/12 10:55 AM
Ashville, Manitoba, Canada
superbeeman69 Offline
super street
super street
I asked a similar question a few months back.
https://board.moparts.org/ubbthreads/show...rue#Post7367398
This should help out!
1970 FM3 Coronet 440, 1971 FJ6 Dude D100
Re: Rallye wheel cap refinishing [Re: lilmoose102] #1356695
12/22/12 04:07 PM
12/22/12 04:07 PM
STL
cdstl Offline
cdstl  Offline
STL
Here's mine. I just did eight of these things and will start on some 70-71s soon. First I scuffed the potmetal with 120 grit. Then I used the Krylon 2522 Silver followed by a misting of Krylon 51511 Brilliant Silver and finally Krylon clear satin. Since this paint is textured it filled in even the biggest pock marks like the one in the picture. Ace hardware told me that Krylon discontinued the 2522 Silver so I bought five cans. I still have some left in one can after doing eight centers.
I may skip the Brilliant Silver the next time.
I am pretty happy with the results.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Rallye wheel cap refinishing [Re: cdstl] #1356696
12/23/12 05:12 PM
12/23/12 05:12 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Actually nobody have prooven the later style should be texturized. I got some used ones in good conditions last years and they weren't texturized.
Unles texture is sooooo light that is really hard to tell
Color was hard to "match" out of the can, but finally got what I think is the TRUE aluminium gray shade which is something in the middle of both pics shown:
it gets a clear coat too, but at the end the clear finish goes out.
Here is how it did came out:
note shade is JUST A LITTLE BIT DARKER than the rim itself, but not too much. I think earliers "mexican hats" shoud be in that shade too. Of course 71s not.
I didn't use masking tape, found A LOT EASIER apply a light coat of vaseline all over the chromed area, and then remove with a cloth once paint dried or allmost dried.
Even easier to apply the vaseline if you pre heat the caps in the oven... that will help a little bit to stick the paint too.
Re: Rallye wheel cap refinishing [Re: NachoRT74] #1356697
12/23/12 09:55 PM
12/23/12 09:55 PM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
I got 3 sombreros. 2 are textured, 1 is chrome smooth. ??
12 Grand Caravan
06 T&C
02 T&C
96 Breeze
65 Barracuda "S"
Re: Rallye wheel cap refinishing [Re: pishta] #1356698
12/23/12 10:05 PM
12/23/12 10:05 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
1970 = Textured Silver Argent
1971 = Textured Dark Argent
1972 and later = Smooth Silver
Re: Rallye wheel cap refinishing [Re: NachoRT74] #1356699
12/24/12 02:31 PM
12/24/12 02:31 PM
Pizza Bucket
snuggles Offline
snuggles  Offline
Pizza Bucket
I've found that chapstick works well.I've never tried vasoline
