Re: 65 dodge coronet [Re: geol] #1356556
12/27/12 08:44 PM
12/27/12 08:44 PM
Minnesota
peabodyracing Offline
Minnesota
Did you use the Sherman rear wheel arch repair panels? I'd used a pair 2 yrs back on a 65 Belvedere and they weren't bad, but weren't great for the money spent. Wondered if there's a better solution out there I've not discovered yet for next time. Your project looks great!
Lead, follow or get the hell out of the way
Re: 65 dodge coronet [Re: peabodyracing] #1356557
12/27/12 09:35 PM
12/27/12 09:35 PM
ohio
geol Offline OP
geol  Offline OP
ohio
I used panels from Mill's supply.Overall they were stamped pretty poorly and needed a lot of work especially around the lip.There has got to be a better solution for these but at the time I couldn't find one.
Re: 65 dodge coronet [Re: geol] #1356558
12/28/12 01:29 PM
12/28/12 01:29 PM
Minnesota
Minnesota
Same thing I ran into. Thanks
Re: 65 dodge coronet [Re: geol] #1356559
01/18/14 02:54 PM
01/18/14 02:54 PM
ohio
geol Offline OP
geol  Offline OP
ohio
ready to turn the key.getting into the final touches on the Coronet
Re: 65 dodge coronet [Re: geol] #1356560
01/26/14 01:20 PM
01/26/14 01:20 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
thats going to be real nice when your done, .
Re: 65 dodge coronet [Re: lewtot184] #1356561
02/14/14 04:47 AM
02/14/14 04:47 AM
woodcrest, CA
magnum440d100 Offline
woodcrest, CA
Quick question about the cowl. My good friend tim has a 1965 coronet 440. He has had it since he was a teenager in the early 70's. Today, we took the drivers fender off hoping there was a way to get into the cowl area to clean out the leaves and such, but there's only that small hump/drain, and what looks like a bolt hole(?). The cowl also looks like it is one solid piece, so no removing it to clean it out.
How did you clean it out? That is if you did clean it out. Is there a fresh air vent from inside the car that can be pulled to access the cowl?
