Gasket between master cylinder and booster - 70 cuda?? #1356333
12/20/12 03:27 PM
12/20/12 03:27 PM
K
kielbasa Offline OP
kielbasa  Offline OP
K
Hi guys - am reinstalling booster and master back into my car - there wasn't a gasket between the two when I disassembled it. But I see Year One sells a gasket that indeed goes between the mc and booster.
So does it get one??
70 cuda with power discs.
Thanks for any info!
Re: Gasket between master cylinder and booster - 70 cuda?? [Re: kielbasa] #1356334
12/21/12 10:15 AM
12/21/12 10:15 AM
K
kielbasa Offline OP
kielbasa  Offline OP
K
anybody?
Re: Gasket between master cylinder and booster - 70 cuda?? [Re: kielbasa] #1356335
12/21/12 10:46 AM
12/21/12 10:46 AM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
Good morning! Most all that I've seen, and I'm NO expert, have had that gasket. It's like a soft, foam type material. It will work without it. But, it's probably to keep any moisture/dirt out. I put one in my 70 Challenger. Order it from YO. Take care, Jeff
