ARP rocker shaft stud part number? #1355559
12/19/12 03:45 PM
12/19/12 03:45 PM
Dallas, TX
440Brian Offline OP
440Brian  Offline OP
Dallas, TX
I would like to use studs on my new 440/505 engine, rocker arm shafts. Does ARP sell a set? It's for Edelbrock RPM heads and Harland Sharp rocker arms/shafts/hold downs.
Re: ARP rocker shaft stud part number? [Re: 440Brian] #1355560
12/19/12 04:19 PM
12/19/12 04:19 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
I should have them in stock...will PM you later when I get back to the shop.
RIP Monte Smith
Re: ARP rocker shaft stud part number? [Re: 440Brian] #1355561
12/20/12 12:10 AM
12/20/12 12:10 AM
AndyF Offline
AndyF  Offline
I have a few kits left from the last buy that I did.
