Re: Real world weight loss program and it` cost..........
[Re: RMCHRGR]
#1354426
09/17/14 11:46 AM
09/17/14 11:46 AM
fullmetaljacket
RCHR. This may be a little costly, but not as much as you would think and sneaky indeed. Have the front bumper chemically milled (I know an excellent Dipper that I could personally deliver it to) then have it rechromed. Make a few aluminum pencil bar braces to critical points of vibration and it will be a ringer. I agree, I personally don't like painted bumpers. There are flat bolt on hinge type glass hoods out there. I forgot the company/s making them, but once painted like factory, the notion goes away. This is crucial weight taken off high and frontal area of the car. Good dietary measures here. I believe the later Feather Duster and Dart lite hoods may not be the same in style and fit though they have aluminum under support structures. Yes, your hood is a little complicated to make in the lite alloy, but not impossible. Costly yes and four point pinned it would have to be.
Esthetically, I got away with my incorrect four point pinning system for a 65' because my car is a combo of A864, A990 AFX and 2% cars all in one, so it's par for the course.
[Re: dannysbee]
#1354429
09/26/14 08:50 PM
09/26/14 08:50 PM
Posts: 5,160 Texas
dannysbee
Texas
You could make up hidden brackets on the back side of the hood and pins that show in the front. That would be semi stealthly.
Getting old just means you were smarter than some and luckier than others.
[Re: fullmetaljacket]
#1354431
09/27/14 09:40 PM
09/27/14 09:40 PM
fullmetaljacket
This may not apply to most transmission mounts on other cars. But this is what I found, By chance, I happen to weigh the stock rubber transmission mount against the Polyurethane repro mounts on the market by Imperial services and found that the stock mount weighed 1/2 pound more than the Poly mount. It was a pleasant surprise.
I've tried to call Imperial services with no success to see if they (since their mounts are made in house) would use my supplied shaped Titanium trans mount bracket (the one you see in the pictures) and install it into the poly mold to end with a super lightweight mount. Oh well, they don't return or answer their calls.
#1354435
10/04/14 07:53 PM
10/04/14 07:53 PM
fullmetaljacket
Underside with the poly mount in its nest. Will try and get it in the car in a day or so. All of this when all said and done with all mounting bolts shaved 5 lbs. A long look back in this read and fabrication flicks can show how precision it had to be accordingly to the messy factory fabrication itself. I'm surprised on how crude some member/s including K members can be from the factory and survive all these years. I gave it a bit more precision neatness for ease of install and function. Maybe for that reason, it doesn't pass for a factory appearing piece. LOL.
[Re: Thumperdart]
#1354441
10/05/14 03:53 PM
10/05/14 03:53 PM
Posts: 5,160 Texas
dannysbee
Texas
Beautiful job on the transmount!!!
[Re: dannysbee]
#1354442
10/05/14 10:07 PM
10/05/14 10:07 PM
fullmetaljacket
Thank you. I couldn't resist and snuck out to the grotto for a mock up install. Here it is in its cubby. Tranny sitting at its correct level and snug. Wouldn't do this again, but it was lots of fun if that makes sense.
Note the aluminum exhaust system (another venture into madness) and metal matrix propeller shaft. It was the very final Matrix shaft (Last length of metal matrix tubing) that Dyno-tech made being that expenses and minimums went through the roof.
Now to the next phase. All I can say is that it will be ornamental and super trick. Stay tuned. Thanx guys. Hope this spawns other MADMEN out there. LOL. Just think and rethink all you do and use good materials along with knowledgeable welding and fasteners. After that, check and recheck.
#1354443
10/05/14 10:09 PM
10/05/14 10:09 PM
fullmetaljacket
Back side. Its amazing how short of a bridge the trans member is. I guess that just makes it more stubbier and strong along with the chassis cross member. Those old Chrysler corporation engineers were geniuses.
[Re: Thumperdart]
#1354444
10/06/14 09:53 AM
10/06/14 09:53 AM
Posts: 12,339 somwhere
smokinwoody
somwhere
So winters here and what a perfect time to spend in the garage or where ever removing weight from our cars or unless your past that point then you`re probable doing something in the name of lower et`s. For all of us who`d like to see real word lightning programs and the weight lost and the real cost, let`s hear em. Like; Glass compered to lexan or removing metal as I am and the gains et wise or glass doors, deck lid etc. and can these pieces stand up on the street or sitting in the sun?
what a long time running thread...anyways..my 63 Dodge MW, had the complete nose and doors acid dipped from back in the day..the rear quarter windows were replaced with Plexi and the cranks removed but I'll replace the Plexi with Lexan...the entire interior is gutted and metal removed from the inner side of the doors...it's a back half with all metal removed from behind the driver to the rear valance...aluminum will be used to cover where steel once was plus 40" aluminum tubs.......the cage will be all Moly....rear suspension pieces (4-link) are all Moly too....front suspension is all Moly as well and the stock K member and torsion bars removed...
projected weight with a 440 based RB block and TF should be under 2800 lbs..perhaps even less...this will be mostly a street racer (cough)
