Page 45 of 179 1 2 43 44 45 46 47 178 179
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1354066
12/16/13 07:45 PM
12/16/13 07:45 PM
fullmetaljacket Offline
My new scales should be in this week. I have to go pick 'em up at the speed shop. When all settles down after the impending holiday, I'll make the trek to the grotto and gently HALO drop the car onto the scales. I'm just as curious.
I'm guessing numbers too.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1354067
12/16/13 08:30 PM
12/16/13 08:30 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Anyone look into the weight difference between body fillers?
My vinyl top dart had bondo-type filler in the C-pillar seam, where my painted roof car had lead...
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Real world weight loss program and it` cost.......... [Re: OUTLAWD] #1354068
12/16/13 09:38 PM
12/16/13 09:38 PM
Not sure, but I do know that a feather weight filler is made. I just got a gallon of it for the front fenders that my friend is working on. After sanding, it should narrow down to just a dusting on the metal.
A true body man will smudge on a good amount and sand it all off leaving small skim coats.
The lead might have been because of the paint not being an issue where as maybe the vinyl can react differently with bondo.
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1354069
12/16/13 09:38 PM
12/16/13 09:38 PM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
Sorry guys, I'm late to the party. lots of good info here. I'm on a quest to lighten my car over the winter. New moly cage, cut out door impact beams, k-frame mods, etc. Here is a pic of the first project. Lightened up the bumper brackets some at work. Knocked off over 7 lbs per side. I have fiberglass bumpers so strength was not much of an issue.
Randy
Re: Real world weight loss program and it` cost.......... [Re: Dartin] #1354070
12/16/13 09:45 PM
12/16/13 09:45 PM
By the looks of that grille and the mention of impact beams, it looks to be a later model A-body Dart. 73' or 74' vintage?
Those impact beams can be a doozy in weight. That's a good amount of weight to cut off the very front.
Good luck and be light to go with might.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1354071
12/16/13 10:00 PM
12/16/13 10:00 PM
Dartin Offline
Dartin  Offline
Yes, it is a 73 Dart Sport. Crossed the scales at Norwalk in September at 3370 with my slender 210 butt in the seat.
Randy
Re: Real world weight loss program and it` cost.......... [Re: Dartin] #1354072
12/16/13 10:07 PM
12/16/13 10:07 PM
That's pretty decent weight to cross with the pilot for the ride. I don't know how deep you've read into this madness since its 20+ pages now, but try and keep your focus from the door rear jams forward. By how that thing is pullin' 'em though, I'd say you don't need a diet. LOL.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1354073
12/16/13 10:12 PM
12/16/13 10:12 PM
Dartin Offline
Dartin  Offline
Lol, thanks. Still have some issues to sort out, but hopefully next year we can get some more track time and get it into the low 9.40's at about 144-145 mph. Engine made good power on dyno, just need to get it to work in the car.
Randy
Re: Real world weight loss program and it` cost.......... [Re: Dartin] #1354074
12/16/13 11:10 PM
12/16/13 11:10 PM
Correct me, does that thing have a big block in the Hamster cage?
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1354075
12/17/13 08:20 AM
12/17/13 08:20 AM
Dartin Offline
Dartin  Offline
Yessir. 540 Megablock, so no lightweight there, lol.
Randy
Re: Real world weight loss program and it` cost.......... [Re: Dartin] #1354076
12/17/13 12:30 PM
12/17/13 12:30 PM
Had a hint.
That Mega is mega in pounds for sure.
Maybe next time around while using that block, a little skim hone off the outer walls and shaving off some but not all of the unneeded bosses may shave off a few pounds not thought of.
I wish I would have done the same with my blocks motor mount bosses of which I do not use with my engine plate.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1354077
12/17/13 02:51 PM
12/17/13 02:51 PM
new york usa
P
pattyboy 572 Offline
P
new york usa
Lee my 500 inch mega block @4.395 hit the scales @ 272 lbs.. liken my world @ 4.500 @ 143lbs pattyboy!
Re: Real world weight loss program and it` cost.......... [Re: pattyboy 572] #1354078
12/17/13 07:40 PM
12/17/13 07:40 PM
Come again?
Are those figures with the cranks in place from what it seems to read?
Seriously, As how Aluminum blocks and their casting procedures have evolved in this day and age, I would have considered one for my build if it were available way back. 60-80 Lbs right off the front edge is candy to the ears and nothing to snap about.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1354079
12/17/13 07:56 PM
12/17/13 07:56 PM
new york usa
P
P
new york usa
Lee sorry bare block with caps....
Re: Real world weight loss program and it` cost.......... [Re: pattyboy 572] #1354080
12/17/13 10:05 PM
12/17/13 10:05 PM
Excited to get my dash board frame later next week fresh from the bubblin' Chacuzzi. Should shed around 5-7 lbs. Pictures from the vat room soon. Its initial installment will have to wait till I have a few other things ready on deck for installment at the same time.
Plus, I'll have to wait till my scales are under the car to get a weigh in and then go forward from there.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1354081
12/18/13 11:35 PM
12/18/13 11:35 PM
Anybody have a set of headlight buckets that can make the weight scale for a figure?
These are the removable metal buckets that the headlights sit in and then are retained by the trim ring. I just want to know what they weigh.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1354082
12/20/13 10:02 AM
12/20/13 10:02 AM
tboomer Online work
tboomer  Online Work
I may have a pair for my 64 out in the garage that I could put on a postal scale if that would help you.
Re: Real world weight loss program and it` cost.......... [Re: tboomer] #1354083
12/20/13 10:24 AM
12/20/13 10:24 AM
That would be great.
I only need one pair, two buckets to be weighed.
thank you.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1354084
12/20/13 10:50 AM
12/20/13 10:50 AM
tboomer Online work
tboomer  Online Work
Will do...I have to find that harness for James too. Maybe this afternoon I can look!
Re: Real world weight loss program and it` cost.......... [Re: tboomer] #1354085
12/25/13 09:17 PM
12/25/13 09:17 PM
australia
charger410 Offline
charger410  Offline
australia
Just made these up yesterday to fit my carbon/Kevlar doors. Tried lightening the standard hinges but they were still quite heavy
Peter. Australian Charger, alloy block injected 410in, w9 na 9.03@148 leafs 3000lb
1967 barracuda 605 hemi Stage5 millennium 8.2@170
