Page 38 of 180 1 2 36 37 38 39 40 179 180
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353926
08/21/13 12:00 AM
08/21/13 12:00 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Real world weight loss program and it` cost.......... [Re: hemi-itis] #1353927
08/21/13 12:02 AM
08/21/13 12:02 AM
fullmetaljacket Offline
We need to make that roll off bed out of aluminum.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353928
08/21/13 01:33 AM
08/21/13 01:33 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Light is might and Lean is mean.
Will the real Weightwatchers step forward please. LOL.
Are you ready to give a weight on that beast yet? I know you wanted to take more off before you did, cause you wernt quite there yet.
So where are you now??
Will the real Weightwathers step forward please. LOL
Im at 2950# 73 Sport 440. Where are you?. 3200# to ????# Come on, you should be light enough to give us some numbers now
Re: Real world weight loss program and it` cost.......... [Re: Sport440] #1353929
08/21/13 10:31 AM
08/21/13 10:31 AM
I'll be bringing it to a certified truck scale this September to see where it sits at now, I do have a rough guesstimate on the weight, but will wait to see where it is in comparison to where it's now. This is still a heavy B-body guys. It's all metal, no fiberglass, carbon fiber anywhere.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353930
08/21/13 01:54 PM
08/21/13 01:54 PM
Cab_Burge Online work
Cab_Burge  Online Work
I would not weigh anything lightweight(under 25,000 LBs) on a truck scale I weighed my Duster on one of Oregon State Police truck scales with me in it and full of fuel, it weighed 3100 Lbs I took it to Las Vegas to the track and weighed on the track certified scales and it weighed 3450 lbs with me and the same amount of fuel Use a good set of race car scales
Re: Real world weight loss program and it` cost.......... [Re: Cab_Burge] #1353931
08/21/13 02:18 PM
08/21/13 02:18 PM
Much corrected. I could see how it is deceiving being that cars are much much lighter than your average dump truck. I did notice that E-towns scale was off and on the very same day. Fuel was the same as well. Those scales with wood planks may fool themselves if they are wet from a previous rain I've been told.
I will look into some one with accurate car scales here in the NYC area that I may borrow.
Truthfully, based on my previous scale numbers a few years back, I had thought that my car was a lot lighter then what it scaled at.
I mean I've scaled every thing that I have taken off or modified on good digital and mechanical scales to compare. The numbers were dead on between the two types and I've cataloged all the numbers and put them together to see if they matched what the truck,track scales said and not close.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353932
08/21/13 02:50 PM
08/21/13 02:50 PM
State of confusion
Thumperdart Offline OP
State of confusion
I agree w/Cab.............find a roundy round guy or a chassis shop w/4 corner scales so you can see side to side and ft. to rear #`s..............
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1353933
09/04/13 02:36 PM
09/04/13 02:36 PM
Renton Washington
Triple Threat Offline
Renton Washington
How's the aluminum exhaust working out?
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Real world weight loss program and it` cost.......... [Re: Triple Threat] #1353934
09/04/13 10:43 PM
09/04/13 10:43 PM
hemi-itis Offline
hemi-itis  Offline
Lee,you said the e/town scale was off How much was it off and which way was it off??? That is the scale I drove onto with a heavy reading??????????
Re: Real world weight loss program and it` cost.......... [Re: hemi-itis] #1353935
09/04/13 11:12 PM
09/04/13 11:12 PM
remembering it being on heavy side of things. about 60 or so pounds too heavy.
Re: Real world weight loss program and it` cost.......... [Re: Triple Threat] #1353936
09/04/13 11:18 PM
09/04/13 11:18 PM
Triple.
Exhaust is on and it sounds awesome. Have not driven it yet for the long street test haul, will do very soon. Very busy with work.
I'll post flicks as soon as I can, maybe by this weekend.
The mufflers are tucked nicely away in the muffler cavity of the under body. The exhaust ever so slightly veers upwards from the collector point to assist in the Heat rises theory. Maybe that alone enhances the flow which is much needed with an aluminum exhaust.
In this case, size does matter. I was told by Chris over at Unobtanium that the larger the tube size, the better scavenging of heat to keep the system from getting too hot.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353937
09/05/13 12:43 AM
09/05/13 12:43 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Here is a little factory trick I shouldn't let fly but what the hay.
For all of you 66-67 b-body guys:
The Coronet Deluxe (aka poverty model) used a plastic lower steering column instead of a metal one like the 440/500 models and Charger. Low hanging fruit is the best.
Re: Real world weight loss program and it` cost.......... [Re: Jeremiah] #1353938
09/05/13 12:44 AM
09/05/13 12:44 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
That space age plastic sure is feather weight.
Re: Real world weight loss program and it` cost.......... [Re: Jeremiah] #1353939
09/05/13 09:00 AM
09/05/13 09:00 AM
I love when factory things like this are discovered. Cheap weight reduction at its best.
The one on my car is a factory plastic piece. Lightweight is an understatement.
Re: Real world weight loss program and it` cost.......... [Re: Jeremiah] #1353940
09/05/13 12:56 PM
09/05/13 12:56 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
I thought '67's were plastic and '66's metal.
Re: Real world weight loss program and it` cost.......... [Re: @#$%&*!] #1353941
09/08/13 05:30 PM
09/08/13 05:30 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I could be wrong? The plastic piece in my pic came from a '66 Deluxe. Maybe it was a really late car. Thank you for the clarification.
Re: Real world weight loss program and it` cost.......... [Re: Jeremiah] #1353942
09/08/13 05:37 PM
09/08/13 05:37 PM
I've got a few flicks coming of some rather minute micro items, but never the less, one more ounce takes the count.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353943
09/08/13 07:06 PM
09/08/13 07:06 PM
hemi-itis Offline
hemi-itis  Offline
Ahhh,some Jenni Craig vid's
Re: Real world weight loss program and it` cost.......... [Re: hemi-itis] #1353944
09/09/13 09:29 AM
09/09/13 09:29 AM
Seat belt mounting bolts were 1/2 pound for all four pieces. Titanium pedigree was a 1/4 pound for all four pieces.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353945
10/09/13 04:57 PM
10/09/13 04:57 PM
Yo! This just in and NHRA just approved it for competition. The first ever Renold's aluminum foil ultra-liteweight roll-bar assembly. It weighs in at 1/2 pound total and can be hand formed into shape and fitment. LOL.
Don't try this at HOME-track, it's just there for masking while I paint my interior floors/panels. Ultra-trick masking trick it is while painting.
