Re: Real world weight loss program and it` cost..........
[Re: Thumperdart]
#1353737
03/13/13 10:44 PM
03/13/13 10:44 PM
Thumperdart
State of confusion
Put the 2nd. batt. back in and here`s the #`s; l.ft. 741 r. ft. 827 l. r. 781 r. r. 657 So it looks like I`ve got my work cut out................
[Re: Thumperdart]
#1353738
03/13/13 11:04 PM
03/13/13 11:04 PM
Posts: 456 corpus christi tex
Cheatham
corpus christi tex
2980#...Good luck,Thumpman!!
You were the closest...........2972 w/me and about 6 galons of gas. Here`s the #`s; w/me............ lt. ft. 758 rt. ft. 823 l r. 760 l r. 631 This seems goofy to me.
Bought some nice used Rebco scales from R/J. I didnt level the scales i just wanted a total weight so here it is without me in it LF 801 RF 756 LR 543 RR 560 Total 2660 With me in it i weigh 165 LF 854 RF 782 LR 621 RR 573 Total 2828 With 440, aluminum heads, Slant 6 Rad. all stock front susp.except upper a-arm tubeular all lexan glass doors, hood, bumpers, lite wt bumper brackets Full moly cage, back halfed with 2x3x083, dana 60, 14x32 rears 5x7 Goodrich fronts, 7 gall fuel, all fluids topped off, Dash cut in half, 3/4in steering shaft, lite wt steering wheel, Kirky alum seat. Next to change soon All alum 572, alum tie rod sleeves with hiems, alum strut rods, remove 1.030 torsion bars replace with .890s K frame on a diet, wish i had the money for a alter k but i got house work to do. Id like to get this car in the 2500lb range. o ya its a 73 with all the lights and mufflers barely street legal. Thought id share.
[Re: Cheatham]
#1353739
03/13/13 11:10 PM
03/13/13 11:10 PM
Thumperdart
State of confusion
Your rear weights look good to me but mine are WAY off but after looking at my car on the scales, the ft. end is still not settled so I`ll mess w/it some more............
[Re: Thumperdart]
#1353740
03/13/13 11:11 PM
03/13/13 11:11 PM
Posts: 9,857 MI, usa
dvw
MI, usa
That looks to me to be 3006lbs, My 3039lbs looks pretty close. I wish mine was that light. Doug
[Re: Thumperdart]
#1353742
03/13/13 11:39 PM
03/13/13 11:39 PM
dvw
MI, usa
After shaking the car around and letting it settle it looks like this; w/me total 2967 lbs.
l.ft. 758 r.ft. 819
l.r. 759 r.r 631 The rear #`s just looked jacked to me and thaught it was posted here to get the rear #`s withih 30-40 lbs.
That's even better, If I'm with in 300 lbs of that I'd be happy. Doug
[Re: dvw]
#1353744
03/14/13 12:00 AM
03/14/13 12:00 AM
Posts: 6,780 Alabama
Mopar-Al
Alabama
Dom, what was your tire pressure? 35 ft ? What was the rear? What other places were you going to remove weight?? Good to see you getting about 200 lbs off of it so far
[Re: Mopar-Al]
#1353745
03/14/13 12:05 AM
03/14/13 12:05 AM
Thumperdart
State of confusion
Rears were 12 lbs. and the ft`s were 38..............Still going to a lexan ft. glass in the stock rubber, lower strut rods(alum)and ft. race tires which I would hope would remove another 25+ lbs. from the ft..................
