Re: Real world weight loss program and it` cost..........
[Re: fullmetaljacket]
#1353486
01/19/13 12:06 AM
01/19/13 12:06 AM
fullmetaljacket
While we're on the doors, here is a stock striker with backing plate and mounting hardware, Underneath is the new aluminum backing plate I cut out. When I get the 7075 Aluminum strikers from Detroit where they're being milled, I'll post up a flick or two. This process only saves about 1-1/2 Lbs between the both sides.
#1353487
01/19/13 12:14 AM
01/19/13 12:14 AM
fullmetaljacket
untapped Aluminum backing plate. Fairly easy to cut out and tap.
#1353488
01/21/13 02:42 AM
01/21/13 02:42 AM
fullmetaljacket
Here's a few tricks known and not so known to be done to any interior of any Mopar both street and strip. * Quarter window cranks in place of the larger front door window cranks. Smaller and lighter by 3/4 lb. * Headliner insulator and lower cowl sound deadners along with the coat hooks. 2-1/2 lbs. Who needs coats in the Summer months. * Sunvisors and hardware. 3 lbs. A good pair of Sunglasses can help. * Rear view mirror trimming. Here's an example of my original early B-body mirror with the sun visor docks cut off and trimming on the main spine. 1/2 lb.
#1353491
01/23/13 10:13 PM
01/23/13 10:13 PM
Posts: 9,871 MI, usa
dvw
MI, usa
Anymore Davey Jones locker secrets out there that need to be shared? I know some of you are keen and lean with some new tricks. I especially liked the downwards hood pin deal that the cat with the sleeper Turquoise 62' Savoy created.
The apple doesn't fall from the tree. That's my sons car. Your stuff amazes me. I like the mirror Doug
[Re: Thumperdart]
#1353492
01/23/13 10:28 PM
01/23/13 10:28 PM
fullmetaljacket
Your Lexan windshield should not be too hard to form since it has a rather modest contour. Just take your time and shut off the cell and it will all go well. You should shave at least 10 lbs from that glass alone. Is the plastic rear mirror you're using look like your current one? Those side door mirrors can weigh much as well. I kept mine so as to keep the heat away from giving me flack. I've been busy lately with work, but I have a few ideas in the works and/or already implanted. When I get a moment, I'll post 'em.
[Re: Thumperdart]
#1353495
01/23/13 11:12 PM
01/23/13 11:12 PM
Posts: 4,210 New York
polyspheric
New York
Sorry to throw cold water on a cherished method, but all of the formulas ("1 lb. of rotating weight is worth X lbs. of static weight") are completely wrong. On some cars, the result may be ballpark by accident, but why would removing 1 lb. rotating weight at 5" from its rotational center (like a crank CW) in a 2,500 lb. chassis have any relation at all to removing 1 lb. from the center of an axle in a 5,000 lb. chassis?
It doesn't. The math for equivalent effect must include the RPM and the effective center of rotating mass.
Re: Weight ahead of the CG almost always helps ET Did no-one notice that this is backward?
Boffin Emeritus
[Re: polyspheric]
#1353496
01/23/13 11:26 PM
01/23/13 11:26 PM
fullmetaljacket
"Weight at the front of CG helps ET" This came off wrong to me as well, but then I figured after reading it over a few times that what Wize was trying to actually say was: weight REMOVED from the front of CG would help ET. I personally have looked into removing rotational weight from using different weight tires more than actual wheels. I found that my car cut ET by two tenths by switching to lighter tires, and then not much at all from lighter wheels.
[Re: Cheatham]
#1353502
01/24/13 01:31 AM
01/24/13 01:31 AM
fullmetaljacket
I agree with ThumperD on the roof supports. I'd leave them in if no Full Roll cage is present. I also have given the center cross brace some thought where the Dome light goes and figured that even though it would probably do nothing much on a roll over, it helps a little to keep the roof in its intended shape. I did remove the Dome light assembly on mine which shaved 3/4 lb. I only have a 12 point roll bar/Halo in my car, not a cage as some of my well informed friends have indicated in the past. Roll cage and Roll bar are two siblings of a different Father, one being Big Brother, the other being the brat kid. In a fantasy no expense sheik type of built, I would some how have the front longitudes, K-member, fender aprons, radiator cross brace, firewall, fenders, Bumpers, hood and doors all made out of Aluminum. This would all then be bolted and super Hi-tech glued to the main body, B pillars with roof which would be made out of Titanium and the rear quarters and Bumper out of cold roll steel. Of course this would all be tide together with a super stealthy chrome-moly Roll cage hidden inside. In other words, the weight increases in the direction of the rear of the car. Talk about a CG Lightweight masterpiece. Talk about wishful thinking. LOL.
#1353503
01/24/13 01:34 AM
01/24/13 01:34 AM
Thumperdart
State of confusion
I agree with ThumperD on the roof supports. I'd leave them in if no Full Roll cage is present. I also have given the center cross brace some thought where the Dome light goes and figured that even though it would probably do nothing much on a roll over, it helps a little to keep the roof in its intended shape. I did remove the Dome light assembly on mine which shaved 3/4 lb. I only have a 12 point roll bar/Halo in my car, not a cage as some of my well informed friends have indicated in the past. Roll cage and Roll bar are two siblings of a different Father, one being Big Brother, the other being the brat kid. In a fantasy no expense sheik type of built, I would some how have the front longitudes, K-member, fender aprons, radiator cross brace, firewall, fenders, Bumpers, hood and doors all made out of Aluminum. This would all then be bolted and super Hi-tech glued to the main body, B pillars with roof which would be made out of Titanium and the rear quarters and Bumper out of cold roll steel. In other words, the weight increases in the direction of the rear of the car. Talk about a CG Lightweight masterpiece. Talk about wishful thinking. LOL.
Talk about wads of greenbacks.............
#1353504
01/24/13 01:48 AM
01/24/13 01:48 AM
fullmetaljacket
A whiles back at the Nationals, I met a 69 year old lightweightronist that was hand building some rather unique lightweight pieces for his 64' Plymouth stocker in the 70's. He mentioned that he was cleaning up the clocks with speed stemming from his covert light weight program. So as he told me, he revisited those practices again for fun in helping cats like us with stealthy projects. He started with the lightweight pieces you see below under the Frye Racing banner. I bought both the large firewall mounted aluminum brake reservoir plate and Distributor hold down from him. The mounting plate is a dead ringer for the original and it shaved 1 lb off. The Distributor hold down was also stealthy except for the holes that he drilled out. After that, I never saw him again and I lost his contacts. He was from Indiana or some place like that and could talk up a storm about his tricks.
