Re: Real world weight loss program and it` cost..........
[Re: fullmetaljacket]
#1353428
01/14/13 03:00 PM
01/14/13 03:00 PM
fullmetaljacket
The 64's, though their grilles,headlamp buckets and trim were more handsome than the 65's, they were also slightly heavier. The 65's flat mug called for some cheap and lighter material as opposed to the sturdier 64'mugs. I love the 64' Post Sedans and Hardtops much better than the 65's, but the 65' Post Sedans are a tad leaner. I'll take it. Every ounce counts.
[Re: MPerry]
#1353431
01/14/13 04:49 PM
01/14/13 04:49 PM
fullmetaljacket
Excuse my sarcasm. but there's no trick in deleting a whole hood. I would think that a cleverly gutted hood is more the flavor pill for your car, plus the absence of it would create such an aerodynamic drag that it would contradict the weight savings. I think it is illegal to run with out one in the door classes as well. In real world theory, I think your hood can be gutted a little bit here and there and still use the hinges and latches. The extreme method being to gut it in a precise surgical way where four hood pins (Aluminum) could be the anchors for the hood and it still is steel. Probably will only shave about 20 lbs going the extreme route. I'm not sure what glass companies may be out there that make good quality hoods that are that long in size and still retain a firm good looking stance. Homework. The K member is another story. You would just have to really study the whole animal and make good real sound decisions. I know that there are many little pockets in that car that can be leaned out. maybe an ounce here, a pound there, but it could be done till a maximum point in street trim. Good luck.
#1353432
01/14/13 05:32 PM
01/14/13 05:32 PM
Posts: 11,657 Fitchburg,Massachusetts
MPerry
Mopahts memba'
Mopahts memba'
7.8 HOOD
Optional. Carburetors must be covered by flash shield or scoop. Hood scoop may not extend more than 11-inches (27.9 cm) above height of hood surface. See General Regulations 1.4.
I'm not buying the drag part either. I won't be running over 200mph where that would be more of a concern. I'm more interested in getting better weight transfer so I can hook.
#1353435
01/14/13 08:52 PM
01/14/13 08:52 PM
Posts: 9,862 MI, usa
dvw
MI, usa
If I remember correctly from 10 years back, a distant friends 64' Dodge 500 Polara Hardtop that we were putting on a slight diet had his steel front bumper coming in at 36 lbs alone. The brackets I honestly do not remember as he never kept detailed logs like I do and he let it go out the back door at the end. My 65' front bumper came in at 27-1/2 lbs and I know that his was heavier because the 64's were slightly longer cars and a tad heavier than the 65's. I don't use Fiberglass but I would give a good guesstimate for a front bumper to be at 3-5 lbs alone.
The 64' bumper brackets were bulkier than the simple 65's. Slightly easier to make out of Aluminum, but there's a slight radius that needs to be respected so that the bumper fits like stock.
64 front bumper 22.5lbs, rear bumper 24lbs. All brackets front and rear 26lbs. All 6 bumper brackets in carbon fiber 2lbs. AAR fiberglas hood, 21lbs, very nice hood. Aluminum pins and brackets, of coarse. Doug
[Re: dvw]
#1353436
01/14/13 08:56 PM
01/14/13 08:56 PM
dvw
MI, usa
#1353444
01/14/13 10:13 PM
01/14/13 10:13 PM
fullmetaljacket
Underside with cross support braces and flat stock hood pin load supports.
#1353445
01/14/13 10:16 PM
01/14/13 10:16 PM
fullmetaljacket
I had built the 65'AFX height scoop in 1999 after many tries to have Kramer produce them in fiberglass. Glad I was persistent in making mine out of Aluminum. Made the scoop with a few blocks of wood, body hammer, stairwell railing in the Housing projects to make the bends, and a little welding on the corners. Stock steel hood with this scoop at first weighed 79 lbs. Gutted steel hood with scoop then weighed 52 lbs. No cost except the 3003 Aluminum sheet. $40.00 Aluminum hood with Aluminum AFX scoop weighs in at 25 lbs. Cost $90.00 5'X10'3003 Aluminum sheet and my friends patience. Heavier than a glass hood but keeping to the name Fullmetaljacket.
