Re: Real world weight loss program and it` cost..........
[Re: fullmetaljacket]
#1353306
12/29/12 12:55 PM
12/29/12 12:55 PM
Posts: 9,890 MI, usa
dvw
MI, usa
Had it spun like 8 years back. I than made the copy over of the trimming, notching, tapped holes and all using a stock steel column. Saved about 3-1/2 lbs. Material and spinning cost me 100.00 but I don't think he is in the same place anymore and the cost have probably gone up since.
The main weight in the column is the shaft and stock wheel. I made the shaft from .090"x3/4" moly. I had to keep the stock wheel. I'm stuck on this "stock look". Doug
[Re: dvw]
#1353307
12/29/12 05:25 PM
12/29/12 05:25 PM
fullmetaljacket
Yes and No on the column assembly weight conviction. I also had the steering shaft remade from Chrome-moly tubing with a swinging joint by Bondo-Bobs fabrication and that in itself saved 3-1/4 lbs. Factor in the stock looking steering wheel, lightweight fasteners, washers and the Alloy column and you have 10 lbs scavenged off the front. A little fiendish, but fun in the process. The steering column/brake pedal mounting bracket underneath the dash is also of the Allu-alloy along with all cross bar supports and fasteners. Super trick and another 4 lbs shaved off for a grand total of 14 lbs.
[Re: dvw]
#1353308
12/29/12 05:46 PM
12/29/12 05:46 PM
fullmetaljacket
Next time anyone is under their dashes and happen to have the pot metal instrument cluster removed, take a minute to see how much that puppy weighs. Mine weighed 3 pounds Stock. I shaved off 1 lb all together by hole saw drilling the real-estate of the back side which is thick walled and was not serving anything and there after taped over the newly cut cavities with good 3M Gaffers White tape to help restore reflection for the inner lights.
#1353312
12/30/12 07:18 PM
12/30/12 07:18 PM
dvw
MI, usa
DVW. You have craft in your blood. Keep up the great work. Keep that B-body lightweight.
That's the fun in building it. And yes the cast cluster is gone. You can't see all the holes in the brake pedal. Doug
#1353315
12/31/12 11:25 PM
12/31/12 11:25 PM
fullmetaljacket
Not exactly a Mopar, but respectably FAST,COOL and LIGHTWEIGHT. Many tricks on this car by its 66 year old owner. 3400 lbs and change wet.
#1353316
01/01/13 01:38 PM
01/01/13 01:38 PM
Posts: 159 australia
charger410
australia
I'm going through my Australian Charger at the moment. Not sure if your got something similiar but where your door hinges bolt onto the body there's a removable metal plate in behind which is about 1/4 inch thick steel. I replaced these with an alloy plate, same thickness, tapped the holes to suit. Would have to be 3-4 pounds in them
Peter. Australian Charger, alloy block injected 410in, w9 na 9.03@148 leafs 3000lb
1967 barracuda 605 hemi Stage5 millennium 8.2@170
[Re: charger410]
#1353317
01/01/13 06:10 PM
01/01/13 06:10 PM
fullmetaljacket
Yes I have, and the Door strikers themselves are being cnc jet cut out of 7075 as we speak in Detroit. These strikers and their backing plates do not weigh much though. 3 lbs all together in stock form, so Alu's would only cut off 1 to 1-1/2 pounds at the most. Where the holy grail is are the door hinges themselves. Mine were sold to me before they even made it to market and now they're asking like $700.00 a pair. They save as much as 8 lbs between two doors.
All of these confessions that have pawed out about the car was only because the CIA made me do it? Freedom of information act I guess. LOL.
[Re: dvw]
#1353323
01/02/13 11:06 AM
01/02/13 11:06 AM
charger410
australia
Over here no one has molds for my car's panels so i had them made. Got the panels made in carbon fiber and this is how much weight they save 2 x doors 50.8 2 x guards 42 hood 35 trunk 17 2 x bumpers 48 total 192 pounds weight saved Had them done to look as much as possible like the original steel ones There not on yet but thats my job for this year ![](http://i1111.photobucket.com/albums/h474/charger410/1357132833870_zpsad751b80.jpg)
[Re: charger410]
#1353325
01/02/13 08:14 PM
01/02/13 08:14 PM
fullmetaljacket
Good weight loss program there with carbon fiber. I've been hell bent on making it possible with Factory lightweight panels or scratch built components with exotic metals, Hence the name: FULLMETALJACKET. The plastic bulbs if I'm correct have to be run with resistors and more wiring and that would off shoot the weight of the glass bulbs which by the way, weigh 3/4 pound each. Probably not worth it.
