Page 5 of 180 1 2 3 4 5 6 7 179 180
Re: Real world weight loss program and it` cost.......... [Re: pittsburghracer] #1353266
12/21/12 12:40 AM
12/21/12 12:40 AM
State of confusion
Thumperdart Offline OP
State of confusion
Thankxxx John, I`ll look into that. I always said if a car has lexan it better run 8`s but may eat my words cos light is right and I need some 9.50`s bad............
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1353267
12/21/12 12:45 AM
12/21/12 12:45 AM
fullmetaljacket Offline
Yes, a while back they were heat molding the windows as per your originals. I bought mine pre-molded from Kramers for the early B's. Your rear window i would prefer to keep in for weight distribution. The front windshield is the lard that needs its walking papers. A note: I do not use windshield wipers since my car is the perfect weather vain. Wipers may result in scratches and blemishes on any Lexan coated or not.
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1353268
12/21/12 12:52 AM
12/21/12 12:52 AM
Thumper. Ship your car to the big Apple and enroll it in my jack-o-Lee's health spa. We'll have that pup floating like a kite in Central Park. LOL.
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1353269
12/21/12 01:01 AM
12/21/12 01:01 AM
West Coast
Pink Dart Offline
Pink Dart  Offline
West Coast
Skin It LOL
Aka: Albergetti
Indy W2's
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1353270
12/21/12 01:17 AM
12/21/12 01:17 AM
Dig this one, I mentioned to Dr. Diff a crazy idea. Though I have not done this one yet I think it can work, but for some reason I'm confused at the moment as to how the axles will bolt on.
if in the market of building a new differential, using either a Dana or 8-3/4 housing, weld on GM housing ends to except GM backing plates and all GM brake hardware. Have the axles flanges be GM bolt pattern and than guest what? GM aluminum drums from your local junked 80's Trans Am, 78-80's Malibu, Monte Carlos' and Camaros.
Moser axles will make any bolt pattern on their axles. I guess a system like the C-clip eliminator kit can work.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #1353271
12/21/12 01:39 AM
12/21/12 01:39 AM
State of confusion
State of confusion
No wipers here either and I planned on leaving the rear glass in place but everything else that I can remove, will be eleminated.
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1353272
12/21/12 07:34 AM
12/21/12 07:34 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
All done
Again, great work............. I wish I had a full framed door like yours but I`ll make mine work. I just ditched the regular door handle and I`ve seen guys re-locate it up top and use flat stock alum. as the new handle which I think I may have to do...........
My 63 Polara was done the same way,but it was a hard top. I did use 3/16" for it though I take weight from everywhere,front or back.
Re: Real world weight loss program and it` cost.......... [Re: dvw] #1353273
12/21/12 07:55 AM
12/21/12 07:55 AM
Utah
topbrent Offline
topbrent  Offline
Utah
Here is some of Ron Silva's lightening efforts on his old Valiant.
Here is a bumper bracket.
Re: Real world weight loss program and it` cost.......... [Re: topbrent] #1353274
12/21/12 07:58 AM
12/21/12 07:58 AM
Utah
topbrent Offline
topbrent  Offline
Utah
Ron Silva's method to lighten bolts.
Re: Real world weight loss program and it` cost.......... [Re: topbrent] #1353275
12/21/12 08:01 AM
12/21/12 08:01 AM
Utah
topbrent Offline
topbrent  Offline
Utah
Ron Silva:
Drilled Draglink.
Re: Real world weight loss program and it` cost.......... [Re: topbrent] #1353276
12/21/12 08:02 AM
12/21/12 08:02 AM
Utah
topbrent Offline
topbrent  Offline
Utah
Ron Silva:
Drilled steering column shaft.
Re: Real world weight loss program and it` cost.......... [Re: topbrent] #1353277
12/21/12 08:11 AM
12/21/12 08:11 AM
Utah
topbrent Offline
topbrent  Offline
Utah
Ron Silva:
Interior.
No dirt or dust...anywhere!
No Heater, No wipers, no radio, drilled aluminum seat brackets, plastic race seats, lightweight steering wheel.
Re: Real world weight loss program and it` cost.......... [Re: topbrent] #1353278
12/21/12 08:18 AM
12/21/12 08:18 AM
Utah
topbrent Offline
topbrent  Offline
Utah
The little details yield impressive results.
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1353279
12/21/12 09:25 AM
12/21/12 09:25 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
when we got our 71 Duster years ago(it's been sold), it weighed with driver 3300lbs...I thought that was really heavy since it had a light weight pin on hood, rear deck and the thin glass doors....
so what I did was...removed all the overweight thick walled roll cage...was out of date anyways and welded in a proper mild steel cage...
next I replaced all the glass with Lexan....any bracket that was removable and wasn't structural was replaced with aluminum..
the fuel cell was replace with a 10gal aluminum tanks versus the heavy plastic caved in tank...
at weigh in with my wife as driver, it was just under 2700lbs...
the 63 Dodge that I'm building, should come in at 2800lbs...the entire back half will be aluminum including the tubs...the cage will be molly tubing...the front half is boxed and will have an AlterKtion front assembly, the rear suspension is a 4-link using Molly tubes...Im keep the factory glass but will have Lexan roll ups...this will be a street/strip car
Re: Real world weight loss program and it` cost.......... [Re: topbrent] #1353280
12/21/12 12:55 PM
12/21/12 12:55 PM
State of confusion
State of confusion
Ya Ron lightened everything possible but cleanly which is doable. After taking a good look at my car I feel 100 lbs. MAY be doable but my work is defintely cut out for sure. Thankxx for the motivation guys............... I need to make door panels to replace my warped junk so what`s the thinnest lightest material to use. Anyone use thin wood or paneling and cover em?
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1353281
12/21/12 03:37 PM
12/21/12 03:37 PM
West Coast
Pink Dart Offline
Pink Dart  Offline
West Coast
You can get plastic cardboard at home depo.
Real light and durable ???
Just a thought
Aka: Albergetti
Indy W2's
Re: Real world weight loss program and it` cost.......... [Re: Pink Dart] #1353282
12/21/12 03:40 PM
12/21/12 03:40 PM
State of confusion
State of confusion
Thankxxx al...........can`t wait to get back to Famoso for my "impossible" 9.59@ 137 timeslip.........
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1353283
12/21/12 04:11 PM
12/21/12 04:11 PM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
I went to lexan rear quarter windows.
The glass / regulator / hardware was weighed .
28 lbs total
Re: Real world weight loss program and it` cost.......... [Re: topbrent] #1353284
12/21/12 04:24 PM
12/21/12 04:24 PM
I fabricated my centerlink from hollow chrome-moly tubing which we plug welded and seam welded all around to the original link ends. Saved 3 lbs.
Thumper.
You can use thin gauge sheet aluminum for the door panels and use a good industrial glue to adhere the panel material. Magnesium is prone to being flammable, a no no for interior work.
I've also fabricated the top portion of the door panel out of aluminum. The originals are slightly heavy steel stampings. saved about a 1-1/2 lbs.
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #1353285
12/21/12 04:28 PM
12/21/12 04:28 PM
The first few hundred pounds in some instances is always the easiest. The remaining two or so hundred pounds is the hardest and or expensive, but so is rebuilding motors, transmissions, rears that need to pull some of these lead sleds down the quarter.
