Metering Block Options??? #1352775
12/16/12 08:02 PM
12/16/12 08:02 PM
N.E. Ohio
6bblFLASH Offline OP
N.E. Ohio
Looking to try different metering blocks on a HP950 "copy" carb.
Basic issue is WOT AFR. Goes to 13.0 AFR at the hit of the throttle no matter the jet and stays there.
Borrowed a HP-950 Holley and AFR read 11.8 at the same WOT checks.
Been althrough the thing. Tuned it to 14mpg/idles drives perfect ,but WOT cannot be adjusted.
Need a new carb.,,, but hope just metering blocks will do it too?
What metering blocks are decent at a reasonable cost?
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Metering Block Options??? [Re: 6bblFLASH] #1352776
12/16/12 08:40 PM
12/16/12 08:40 PM
AndyF Offline
AndyF  Offline
Bo Laws is a good place to go for metering blocks.
Re: Metering Block Options??? [Re: 6bblFLASH] #1352777
12/17/12 01:10 AM
12/17/12 01:10 AM
Find the problem, fuel feed restriction, and fix it What size needles and seats are in your copy cat HP950?
Re: Metering Block Options??? [Re: Cab_Burge] #1352778
12/17/12 01:16 AM
12/17/12 01:16 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
BlP metering blocks.
Re: Metering Block Options??? [Re: Cab_Burge] #1352779
12/17/12 07:24 AM
12/17/12 07:24 AM
N.E. Ohio
N.E. Ohio
Has .150 N/seats in it,used my fuel-bowls and lines on both. I think its more the fuel curve than avaiable flow
Re: Metering Block Options??? [Re: 6bblFLASH] #1352780
12/17/12 02:39 PM
12/17/12 02:39 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
That's not the best picture... what brand of "copycat" metering blocks and main body did that carb come with?
Re: Metering Block Options??? [Re: 6bblFLASH] #1352781
12/17/12 07:53 PM
12/17/12 07:53 PM
Aubrey, Texas
O
oldtimer5151 Offline
O
Aubrey, Texas
The .150 seats are for alcohol. The largest gas is .130 with viton rubber tips.
Re: Metering Block Options??? [Re: oldtimer5151] #1352782
12/17/12 10:46 PM
12/17/12 10:46 PM
N.E. Ohio
N.E. Ohio
Yep! Tried`em anyway. No improvement
Re: Metering Block Options??? [Re: BradH] #1352783
12/17/12 10:47 PM
12/17/12 10:47 PM
N.E. Ohio
N.E. Ohio
Have no idea,they are pretty coursely machined.
Found shavings inside too............
Re: Metering Block Options??? [Re: 6bblFLASH] #1352784
12/17/12 11:51 PM
12/17/12 11:51 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`m not a fan of frankenstein carbs myself and always had better luck w/a matched unit and tune from there..............good luck either way.
Re: Metering Block Options??? [Re: 6bblFLASH] #1352785
12/18/12 03:38 PM
12/18/12 03:38 PM
dogdays Offline
dogdays  Offline
The supercharger is sucking so much air that the power valve stays closed. It's been an issue for others before, may be for you too. That's my guess.
R.
Re: Metering Block Options??? [Re: dogdays] #1352786
12/18/12 08:03 PM
12/18/12 08:03 PM
N.E. Ohio
N.E. Ohio
R.
Power-valve is boost referenced,also tried with and without power-valve+8jets.
I`ve run from 84`s to 99`s still AFR of 13.0
Re: Metering Block Options??? [Re: 6bblFLASH] #1352787
12/18/12 08:24 PM
12/18/12 08:24 PM
Aubrey, Texas
O
O
Aubrey, Texas
Try raising the carb by installing spacers under it. This will move the carb up maybe not up setting the carbs signal.
Re: Metering Block Options??? [Re: oldtimer5151] #1352788
12/19/12 01:31 PM
12/19/12 01:31 PM
dogdays Offline
dogdays  Offline
Then I've got nothing.
R.
Re: Metering Block Options??? [Re: 6bblFLASH] #1352789
12/19/12 01:35 PM
12/19/12 01:35 PM
BradH Offline
BradH  Offline
If that's a ProComp-based copy, it could be either the metering blocks or the main body having restrictions in the fuel passages.
Try Holley metering blocks w/ the current main body to see if that cures the problem.
If the metering block swap doesn't fix it, it could be something like the downleg boosters haven't been sized properly to flow enough fuel for your use.
My (and I know it's easy to spend other people's $$$), is to sh!t-can the Horrey calb and put a proven unit on it, rather than expend any time & $ trying to band-aid the offshore parts.
