Page 2 of 3 1 2 3
Re: Ladder bars on A body [Re: dvw] #1352728
12/29/12 10:06 AM
12/29/12 10:06 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
the bottom
Re: Ladder bars on A body [Re: dvw] #1352729
12/29/12 10:20 AM
12/29/12 10:20 AM
Howell,MI
Moparpoor Offline
Moparpoor  Offline
Howell,MI
I like the setup dvw !!!
Re: Ladder bars on A body [Re: bigtimeauto] #1352730
12/29/12 10:51 AM
12/29/12 10:51 AM
gregsdart Offline
gregsdart  Offline
take the eaxhaust off, PUT the crossmember where it needs to be, then fix the exhaust.
A custom bent piece of tubing made for the front mount to clear where you want to put both the exhaust and the ladderbar mounting cross bar is may be a good idea here. You will not have to compromise as much. With the front bar mounted below the frame connecters the ride height will be way to high. In order to get it right, you may have to move the exhaust in closer to the driveshaft? The roundy round crowd uses rectangular exhaust tube in some locatoions for ground clearance, and you might be able to do the same here to clear the cross bar and gain some working room.
This is not the time to compromise. It will affect too many things if not done right.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: Ladder bars on A body [Re: gregsdart] #1352731
12/29/12 12:33 PM
12/29/12 12:33 PM
Rochester, PA (near Pittsburgh...
1974 474 Duster Offline
Here's mine, all Alston parts. Has went 1.30 60' so far. works quite well on any track. See ya, Ken
Re: Ladder bars on A body [Re: dvw] #1352732
12/29/12 03:36 PM
12/29/12 03:36 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Very nicely done dvw !!!
I will post pics of the modification of the front cross member tonight
Dan
Yes Mr.P I kept a 30*-40* angle, thanks for the tip !
Re: Ladder bars on A body [Re: Wedgeman] #1352733
12/30/12 01:49 PM
12/30/12 01:49 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
I had to do some fabrication to keep the exhausts at the same place, lots of welding. But fits perfect ! Final assembly before paint is coming soon.....
Mr. P !! does the angle look ok ?
Re: Ladder bars on A body [Re: Wedgeman] #1352734
12/30/12 01:52 PM
12/30/12 01:52 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Pic of the angle
Re: Ladder bars on A body [Re: Wedgeman] #1352735
12/30/12 02:07 PM
12/30/12 02:07 PM
Stockholm, Sweden
fed Offline
fed  Offline
Stockholm, Sweden
How are you supossed to change the front of the ladderbar?
Looks a little bit of to me!
Cuda, -70
Valiant-65 AWB,
Valiant Signet200 -65 Topchopped dragcar.
Topolino Fuel Altered.
NostalgiaFED Sold,
SuperComp Bantam Altered, Sold
Ex Harlan Thompsons Nitro funny car American Graffiti Sold,
Re: Ladder bars on A body [Re: Wedgeman] #1352736
12/30/12 02:07 PM
12/30/12 02:07 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Pic of the angle
Is this all wrong ? should the holes be vertical so you can adjust the front of the bars up and down ?
the way he got it. you not adjusting anything on that ?
Re: Ladder bars on A body [Re: VernMotor] #1352737
12/30/12 03:01 PM
12/30/12 03:01 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Pic of the angle
totaly wrong. Hopefully it just fell down from not being clamped.
The holes need to be vertical
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Ladder bars on A body [Re: VernMotor] #1352738
12/30/12 03:01 PM
12/30/12 03:01 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Ok I just saw my mistake...!!!
got them wrong in the welding process....
First question: what is the effect of moving the bars up or down ?
Re: Ladder bars on A body [Re: VernMotor] #1352739
12/30/12 03:21 PM
12/30/12 03:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Pic of the angle
Like said here... you have it all wrong.. the front
mounting holes need to be VERTICAL .... thats not
what I meant by 30-40 degrees APPLIED angle
Re: Ladder bars on A body [Re: dvw] #1352740
12/30/12 04:23 PM
12/30/12 04:23 PM
Harrison Township, Michigan
Hemi SS Offline
Hemi SS  Offline
the bottom
Very nice dvw! Whose parts did you use?
Re: Ladder bars on A body [Re: Wedgeman] #1352741
12/30/12 05:54 PM
12/30/12 05:54 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Well with going in to a long response //that is how you in part adjust them.
Re: Ladder bars on A body [Re: Hemi SS] #1352742
12/30/12 05:55 PM
12/30/12 05:55 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
the bottom
Parts are S&W, 36" bars. As to the bracket pic above that might actually work. Think about it. Cars that like the instant center further down probably like it further forward as well. As you adjusted down it would come forward as well. There would have to be enough tire clearance at the front of the well as long as enough for the driveshaft. Would it work? I'm already trying enough off the wall stuff myself , but never say never. Here's the back of mine.
Doug
Re: Ladder bars on A body [Re: dvw] #1352743
12/30/12 06:57 PM
12/30/12 06:57 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
the higher the bar angle the harder hit for a shorter time, lower angle less hit but longer time. Is the short version. If you have stock front suspension (at least 6" of travel)Set your ladder bar around 2* down AT RIDE Height and you will be fine.
Thats the short version, i can't type enough for all of it.
Re: Ladder bars on A body [Re: MR_P_BODY] #1352744
12/30/12 08:23 PM
12/30/12 08:23 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Pic of the angle
Please explain, because I'm getting more and more confused here.......
Re: Ladder bars on A body [Re: Wedgeman] #1352745
12/30/12 08:26 PM
12/30/12 08:26 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Just do this:
Re: Ladder bars on A body [Re: bigtimeauto] #1352746
12/30/12 08:30 PM
12/30/12 08:30 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
here is a drawing:
Re: Ladder bars on A body [Re: bigtimeauto] #1352747
12/30/12 10:02 PM
12/30/12 10:02 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Ok.....I see the up and down adjustments...
But here is what I did
Rear axle is at 16 in from ground
front x memeber at 12in from ground
bar is parallel to the body ( level)
end of ladder bar 1 1/2in lower than x member
Is this part right so far ?
Page 2 of 3 1 2 3
