SB victor 340 vs Super Victor? Any back to back? #1352503
12/16/12 01:45 PM
12/16/12 01:45 PM
Weddington, N.C.
Streetwize Offline OP
Weddington, N.C.
Any test these 2 on a 400+ inch motor? I think the SV should work better on a 340-370" motor up top, but I'm not convinced it would work better on a 4" stroke motor, unless somebody can prove it to me otherwise.
The old Vic has really short runners and with a HVH or Wilson 2" spacer ( 4 hole tapered for first 1" and then open below) seems to work really well on 408-414's with good heads.
I can't see the longer runners of the SV being a plus On a stroker but they may be a lot bigger cross sectionally, haven't compared them side by side though. The taper from the plenum on the SV looks pretty impressive though.
Any back to back tests and conclusions out there??
WIZE
In Car:
Re: SB victor 340 vs Super Victor? Any back to back? [Re: Streetwize] #1352504
12/16/12 01:59 PM
12/16/12 01:59 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I have posted this before but it's been a while
Local area friend and racer has a tube chassis 2400ish pound Cuda. It is ultra well sorted out 400 inch b1ba headed small block. Has different stouter mid 8 sec small block now, but he ran the Brodix heads forever
The car had been a best of I believe 9.03, more typical 9.07-9.13. He used a victor.
Swapped to a super victor, and could barely get it to run real high teens, knocked about a tenth out of it, and the car is/ was real well scienced out, definitely gave the super a chance to work
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: SB victor 340 vs Super Victor? Any back to back? [Re: B3422W5] #1352505
12/16/12 02:27 PM
12/16/12 02:27 PM
Weddington, N.C.
Weddington, N.C.
Thanks, Don
Kind of goes along with my thoughts that longer runners are not really much of an advantage on long stroke/high piston speed motors.
Hoping Vic Bloomer ( who knows the old 340 Vic inside-out) and Brian OU812 at IMM can chime in. Really would like to see a true invective back to back both OOTB, with spacers and modded on a 600 horse 408-416 test mule.
Re: SB victor 340 vs Super Victor? Any back to back? [Re: B3422W5] #1352506
12/16/12 02:29 PM
12/16/12 02:29 PM
Renton Washington
Triple Threat Offline
Renton Washington
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: SB victor 340 vs Super Victor? Any back to back? [Re: Streetwize] #1352507
12/16/12 02:37 PM
12/16/12 02:37 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
About a year and a half ago,I tested Vic Bloomer's Victor against my Super Victor. His Victor was pretty well worked over compared to mine though.
I will have to get my sheets out and let you know the results again,but off the top of my head they weren't all that much different with the same carb/ spacer combination
Keith
Re: SB victor 340 vs Super Victor? Any back to back? [Re: Triple Threat] #1352508
12/16/12 02:55 PM
12/16/12 02:55 PM
Weddington, N.C.
Weddington, N.C.
Dustin,
Please refresh my memory...
Was the Vic 340 Vic's hand ported one going against an OOTB SV? Also, what did the heads flow on that dyno motor. That was a flat tappet cam IIRC, right?
WIZE
In Car:
Re: SB victor 340 vs Super Victor? Any back to back? [Re: Streetwize] #1352509
12/16/12 02:57 PM
12/16/12 02:57 PM
Renton Washington
Renton Washington
Yes I believe so, not totally apples to apples but It's the only test I can recall. Keith, who just posted right above you it is his engine and he did the dynoing.
-Dustin
Re: SB victor 340 vs Super Victor? Any back to back? [Re: Triple Threat] #1352510
12/16/12 03:15 PM
12/16/12 03:15 PM
Weddington, N.C.
Weddington, N.C.
Thanks,
My Vic is a pretty nice piece, probably not as well sciences out as Vic's but I've massaged it pretty well and it's well beyond stock. Been using them for 30+ yrs so I'm comfortable knowing where they need work, as I said the HVH seems to work really well on the Vic.
I was thinking about the SV since it's new to me and it doesn't look like it hurts anything much. The Rocky has plenty of hood clearance and with the Airwolfs the big end should pick up quite a bit up top....headers are still tiny 1 5/8 but I just cut off the 3" collector and welded up a 3 1/2" Schoenfeld slip on combined with a 3 1/2" to 3" flowmaster tapered extender. Too small a collector (almost regardless of primary tube size) will always limit your peak torque RPM and also as a direct result lower your peak HP trajectory (rate of hp gain per 100 rpm)
So I'd like to try an SV, but I don't really have the time to science out any porting gains, so running it OOTB might give me some torque through the middle but looks like it might hurt the top end a tad. My very top end will still be limited by the header tube size, so maxing the torque might help anyway. The combo is light (2950 w/d) but definately aero-challenged on the big end
WIZE
In Car:
Re: SB victor 340 vs Super Victor? Any back to back? [Re: Streetwize] #1352511
12/16/12 04:08 PM
12/16/12 04:08 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
I didn't test mine back to back but I was not bolting on the SV as is. It had heavy port mismatch as well as flange area being cast heavy.
Seems it is made to whittle on. It was my big top end setup that was tested and didn't want to leave a ton on the table.
Re: SB victor 340 vs Super Victor? Any back to back? [Re: DJVCuda] #1352512
12/16/12 04:19 PM
12/16/12 04:19 PM
Northern Indiana
Northern Indiana
As Dave said,definitely made to be whittled on.
The ports as cast were about 318 sized. No way can you just bolt one on and see any gains. I mocked mine up and had Vic do a deep port match and he also did some minor work at the carburetor flange.
Keith
Re: SB victor 340 vs Super Victor? Any back to back? [Re: Dunnuck Racing] #1352513
12/16/12 05:17 PM
12/16/12 05:17 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
My Super Victor wasn't so super out of the box but after some worked it picked up some. I picked it up in a package deal but after playing with it I would never remove a ported victor and replace it with a Super Victor.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: SB victor 340 vs Super Victor? Any back to back? [Re: pittsburghracer] #1352514
12/16/12 05:27 PM
12/16/12 05:27 PM
Weddington, N.C.
Weddington, N.C.
All good info, my thanks to everybody!
I'm thinking the only real meaningful "step up" might be a TR with maybe an 1150 Dommy on it
WIZE
In Car:
Re: SB victor 340 vs Super Victor? Any back to back? [Re: Streetwize] #1352515
12/16/12 06:11 PM
12/16/12 06:11 PM
Weddington, N.C.
Weddington, N.C.
Well somebody bought the Tunnel Ram that's been on the Local Charlotte Crsigslist so I'll be on the lookout for another one.
But I did score a virgin 71 360 block, so now I gotta decide whether to go 4.125" or 4.25" stroke. I'm looking for a fun tow vehicle to tow the Rocky around.
WIZE
In Car:
Re: SB victor 340 vs Super Victor? Any back to back? [Re: Streetwize] #1352516
12/16/12 09:16 PM
12/16/12 09:16 PM
Weddington, N.C.
Weddington, N.C.
Nobody try tunnel rm on their stroker against a Vic?
WIZE
In Car:
Re: SB victor 340 vs Super Victor? Any back to back? [Re: Streetwize] #1352517
12/16/12 09:35 PM
12/16/12 09:35 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Hey Wise Ive not tried it but have been following around 1/2 dozen back to back t ram vs single set ups, it seems the t ram will ave out to a min of 20 ft lbs & 20 hp more some saw 50 hp gains depending on the combo.
Re: SB victor 340 vs Super Victor? Any back to back? [Re: emarine01] #1352518
12/16/12 11:14 PM
12/16/12 11:14 PM
Northern Indiana
Northern Indiana
Wize ,
What is the rest of your combination I see where you talked about a few things but never the whole combination
Keith
Re: SB victor 340 vs Super Victor? Any back to back? [Re: Dunnuck Racing] #1352519
12/16/12 11:28 PM
12/16/12 11:28 PM
Weddington, N.C.
Weddington, N.C.
11.5:1 4.06 x 4.00 340 block
Airwolf 220 heads off the 633 horse dyno thread
Cam motion roller 266/269 @.050 .585/.570 lift
Ported victor 2" HVH spacer
1000 hp pro systems 4150
1 5/8 headers with 3 1/2" collector ( too small but they fit the chassis)
Full 3" system
2950 race weight
Low gear 904 with 4.10 and 295/65 M/T drag radials
3600 stall T/A vert ....too tight but helps keep the short wheelbase Rocky launching straight.
Heads flow 273 at .400 301 @ .500 312 at .600, my shady dell stage 2's flowed about 25-30 less at all points.
Been Talking to Lenny at Ultimate about a looser but still tight-ish 4500 stall 8" but he wants me to see how fast this combo will go first.
WIZE
In Car:
Re: SB victor 340 vs Super Victor? Any back to back? [Re: Streetwize] #1352520
12/17/12 02:04 AM
12/17/12 02:04 AM
Northern Indiana
Northern Indiana
I like your cam choice duration wise,also knowing you use narrow lsa cams. I would like more lift myself .
My car has way too tight of a converter too but it works pretty decent for now. Like Lenny told you,wait and see. If you make more torque It will stall higher anyway.
Keith
Re: SB victor 340 vs Super Victor? Any back to back? [Re: Dunnuck Racing] #1352521
12/17/12 02:28 AM
12/17/12 02:28 AM
Weddington, N.C.
Weddington, N.C.
I'd love to have about .670 lift but the cam I have works well but most of all....it's the one I have.
The way I look at it the new heads flow at .420 what my old ones did at .550 so although I'm not pulling all I could out of them it should still work well and be pretty easy on the springs.
The Victor should work well enough to keep it fun. I really admire Lenny, very straight-up advice.
WIZE
In Car:
