Weird squeak in axle #1351911
12/15/12 10:02 PM
12/15/12 10:02 PM
martinsburg, w.v.
416scamp Offline OP
416scamp  Offline OP
martinsburg, w.v.
Installed moser axles in scamp a few months ago. Have green bearings on them. My left axle makes a squeak noise almost like its rubber rubbing together. Right axle no noise. Anybody have this problem before? Pulled axles and checked them but didn't see anything wrong with them
Re: Weird squeak in axle [Re: 416scamp] #1351912
12/15/12 11:47 PM
12/15/12 11:47 PM
I'd put it up on stands & pull the dr wheel/drum & have a helper idle it in gear & you outside & see if anything is apparent
