aluminum main caps #1351641
12/15/12 11:19 AM
12/15/12 11:19 AM
glendora, ca.
Deepockets Offline OP
glendora, ca.
when i talked to me local machine shop about useing the aluminum mains, he did'nt suguest them. i see that there's a lot of people swear by them on the big blocks. what are the reasons?
Re: aluminum main caps [Re: Deepockets] #1351642
12/15/12 11:23 AM
12/15/12 11:23 AM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
On big inch high HP motors it will cushion the crack so to speak! Kinda the same idea behind using alum rods! Plus it may help stop the stock block from splitting!
Re: aluminum main caps [Re: 70dusterjohn] #1351643
12/15/12 11:51 AM
12/15/12 11:51 AM
glendora, ca.
glendora, ca.
so this is done for mopars only? makes me wonder why don't aluminum after market blocks come them instead of steel?
Re: aluminum main caps [Re: Deepockets] #1351644
12/15/12 12:01 PM
12/15/12 12:01 PM
NC
440Jim Offline
440Jim  Offline
NC
It has to do with the poor (low strength) factory Mopar wedge big block design. If a block is designed for the high loads, it doesn't need them.
Re: aluminum main caps [Re: 440Jim] #1351645
12/15/12 01:45 PM
12/15/12 01:45 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
The oil pressure changes a lot with aluminum caps too. Not a major problem with aluminum rods because they are the last in the oil sequence, but mains need to maintain their clearance. Also, it's much harder to line hone with aluminum caps on an iron block since the caps cut quicker. You can make anything work but is it worth the effort? Most machinists would stay with what they know.
Re: aluminum main caps [Re: Mopar_Rich] #1351646
12/15/12 01:58 PM
12/15/12 01:58 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I have heard somewhere that the mopar blocks were strong block as they have a high nickel content? How are the chevy guys getting away with 1200 hp with factory big blocks? I will be using aluminum main caps on my big block build.
Re: aluminum main caps [Re: Mopar_Rich] #1351647
12/15/12 02:03 PM
12/15/12 02:03 PM
Delray beach, Florida
P
Performance Only Offline
P
Rich, That's the first time i've heard anyone say anything about fluctuating oil pressure when using aluminum caps. I've installed close to a hundred sets over the years and have never had such an issue.
I always align bore the block when installing any cap conversion whether it's steel or aluminum. IMO that's the proper way to do it. some shops will bore the mains to within .001 and hone the rest, which is okay as well.
I believe the aluminum caps help dampen harmonics to some degree. In any case, I think it's been a time tested upgrade to help our stock block combo's live a bit longer when pushed beyond their normal limits.
machine shop owner and engine builder
Re: aluminum main caps [Re: Performance Only] #1351648
12/15/12 02:47 PM
12/15/12 02:47 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
For comparo below we have the SDC/BCR caps on the let and the 440 source caps on the right:
Re: aluminum main caps [Re: Deepockets] #1351649
12/15/12 03:08 PM
12/15/12 03:08 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Either he's a Chevy guy or he doesn't think your power level warrants them.
Re: aluminum main caps [Re: Stanton] #1351650
12/15/12 03:21 PM
12/15/12 03:21 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Or he's a Mopar guy who doesn't believe in using aluminum main caps, regardless of the power level. I know of a couple of Mopar engine builders with that opinion.
Re: aluminum main caps [Re: Performance Only] #1351651
12/15/12 03:22 PM
12/15/12 03:22 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Well, I guess because you are doing things right by setting the bearing clearances accordingly. The oil pressure change is from the extra expansion of aluminum in a hot engine. It doesn't really hurt anything because it's only noticeable at idle on a hot engine. As we all know if the pressure comes right up with RPM we're good to go. There's no question they help absorb shock as do aluminum rods.
Re: aluminum main caps [Re: BradH] #1351652
12/15/12 04:56 PM
12/15/12 04:56 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
I happen to be one of the builders that likes them, uses them, and has what I would consider great success with them. As Rich says, there are some things to be aware of, and machining them can be scary to the guys that dont understand them, but when done properly, I believe they serve a great purpose.A good friend of mine thought I was nuts the first time we spoke of them,and he couldnt for the life of him understand WHY? Yes, he builds a lot of Chevys ( you simplycant compare a Dart Big M block to a stock block Mopar)...lol....but once he saw them in cars running 1200 passes, he became a believer. Its all in the proper machining, set up, timing, and bearing clearances.....carry on....
RIP Monte Smith
Re: aluminum main caps [Re: CompWedgeEngines] #1351653
12/16/12 01:19 AM
12/16/12 01:19 AM
JCFcuda Offline
JCFcuda  Offline
I have them on my 500 Rb . Ive never seen any oil pressure issues.
wouldn't Alu expand in all directions so how would it increase bearing clearance?
Oil pressure was great until I peeled a crane rocker off my head not so good then and then ran it all the way back to the trailer duh .
Re: aluminum main caps [Re: JCFcuda] #1351654
12/16/12 07:23 AM
12/16/12 07:23 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
For what it's Worth the only set I ever ran did have slightly less oil pressure at Idle when hot. This was using the same main clearance .003" as I use with steel caps.
Doug
Re: aluminum main caps [Re: dvw] #1351655
12/16/12 10:32 AM
12/16/12 10:32 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
absolutely nothing wrong wit aluminum main caps, as long as they are align honed prior to use you should be fine. we also offer girdle caps which are beefier than the stock replacement style caps. see the pic in my signature. if your building for 700hp+ i definitely suggest using the girdle, ours is 1/2" thick.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: aluminum main caps [Re: JCFcuda] #1351656
12/16/12 12:27 PM
12/16/12 12:27 PM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
JCFcuda,
A chunk of any metal with a hole in it when heated will cause the hole to enlarge and increase the clearance. Thus the loss of oil pressure when the pump cannot keep enough flow like at idle. When half that chunk of metal is AL then the hole becomes even larger due to heat.
Damon
Re: aluminum main caps [Re: mopardamo] #1351657
12/16/12 02:06 PM
12/16/12 02:06 PM
Cab_Burge Online work
Cab_Burge  Online Work
JCFcuda,
Damon
Half gets bigger than the other half, the bottm half I have used the Mopar Ductile iron with really good results To bad there not avalaible anymore Now, how to decide between steel and aluminum caps Probally aluminum
Re: aluminum main caps [Re: Cab_Burge] #1351658
12/16/12 02:48 PM
12/16/12 02:48 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
I think there is a place for both doctile iron and aluminum. The mixture of unlike metals does not concern me too much as that will always be the case with a aluminum block. Milodon has doctile iron caps available.
Getting old just means you were smarter than some and luckier than others.
Re: aluminum main caps [Re: dannysbee] #1351659
12/16/12 03:00 PM
12/16/12 03:00 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
You naysayers will still be on here talking about expansion rates when I am riding around town giving people lessons on how to spell the word "C H A R G E R" with my aluminum main capped 511 MW victor motor.
Re: aluminum main caps [Re: Jeremiah] #1351660
12/16/12 09:34 PM
12/16/12 09:34 PM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
I don't know about naysayers. If I would of stuck with an iron block I would of had AL caps for sure.
