AAR master cylinder paint question #1351107
12/13/12 10:26 PM
12/13/12 10:26 PM
K
kielbasa Offline OP
kielbasa  Offline OP
K
Hi guys, I'm ready to paint my master cylinder, bale wire, cover and power brake booster.
My question is this: do the 4 fasteners (mc to booster) and the wire harness bracket (that attaches to the booster) get painted also? Thanks!
Re: AAR master cylinder paint question [Re: kielbasa] #1351108
12/13/12 10:49 PM
12/13/12 10:49 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The booster, booster valve, lid, bail, the master cylinder & attaching nuts were painted as an assembly.
The wire loom was added later & held on with a Pal nut.
Re: AAR master cylinder paint question [Re: Alaskan_TA] #1351109
12/16/12 03:52 PM
12/16/12 03:52 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Alaskan T/A
Are you suggesting that the wire loom was not painted black or just not painted black at the same time?
Based on some photos I have, it appears the loom bracket was painted black as well, but the attach nuts were not.
Feedback??
Re: AAR master cylinder paint question [Re: Alaskan_TA] #1351110
12/16/12 03:54 PM
12/16/12 03:54 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: AAR master cylinder paint question [Re: Alaskan_TA] #1351111
12/16/12 04:15 PM
12/16/12 04:15 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Thats interesting, so do you believe that only one PAL nut held the bracket on??
Attached is how mine came off the car
Re: AAR master cylinder paint question [Re: AAR#2] #1351112
12/16/12 04:17 PM
12/16/12 04:17 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
These cars were assembled by multiple people over multiple months, so any number of variables can exist.
Re: AAR master cylinder paint question [Re: Alaskan_TA] #1351113
12/16/12 04:21 PM
12/16/12 04:21 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Seems odd we both show a picture of one nut when clearly 2 could have been installed, biggest variation is the style of nut. That Pal nut doesn't hold much of anything.
I was going to have to start some research on the nut situation as I'm in the middle of redoing mine at the moment, planned to look for the brother of the nut I currently have but perhaps installing only 1 is the answer?
Re: AAR master cylinder paint question [Re: AAR#2] #1351114
12/17/12 12:01 AM
12/17/12 12:01 AM
K
kielbasa Offline OP
kielbasa  Offline OP
K
ok - i have to get a little off topic - but I can't find my pictures (lost in the shuffle somewhere) and for the life of me i can't remember if there was a gasket between the master cyinder and booster. And is there a gasket between the booster and firewall? I have a gasket kit from Detroit Technologies - I'll study it and hopefully draw some conclusions - but thought i'd ask here as well. Thanks for any info!
