Re: B1's - Why not more popular for Big strokers??
[Re: demongup]
#1350301
12/15/12 11:23 AM
12/15/12 11:23 AM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
I am in the middle of building my first B1 combo. I will be able to give a good compassion to the -1 heads. I currently run a 528 ci ,mega block,and nothing off the shelf rotating parts.I am using the same cam, crank ,compression ration..etc .I'm changing the heads ,intake and headers. When I'm done in the next 12-16 weeks I will give some info up
I really think you're going to need a B1 specific cam, or you won't see the real potentail of the heads.
[Re: demongup]
#1350303
12/15/12 11:52 AM
12/15/12 11:52 AM
Posts: 803 Idabel,Oklahoma
Gary Robbins
Idabel,Oklahoma
Original-M/C-PSO ?
[Re: demongup]
#1350305
12/15/12 12:25 PM
12/15/12 12:25 PM
Gary Robbins
Idabel,Oklahoma
B1 originals . I have compared them to the pso . It would take allot of work to fit the cast intake to those. I have had the heads cnc'd and did a lay over onto the pso and there sure is allot of material available on the pso . ....one day .
Kool,will be a great comparison!!!!
My lowdeck -1 540 makes 900ish... The RB B1 original 588 made 1050ish with a little more comp.& cam and surprisingly on 500rpm difference in peak power..
Amen on the PSO'S...I've never ran the top/best heads and PSO'S will be my next head!!!
[Re: demongup]
#1350306
12/15/12 02:29 PM
12/15/12 02:29 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
Josh do tell who is making the CAST aluminum block? Asssuming this is a 5.0 or better BS block? Be nice if they made a 4.9 bore space piece so one could use up the avaiable pro stock heads out there that are plentuful.
[Re: gregsdart]
#1350312
12/16/12 08:06 PM
12/16/12 08:06 PM
Posts: 2,840 Flint, Michigan
B1Fish540
Flint, Michigan
i think a 604 w/B1s would make a good street engine..i would use a purple shaft cam and have the best of both worlds...
Step up to the 650 Comp flat tappet and I bet you would have a winner My uneducated , untried recipe; 604 with B1 heads, Comp 650 cam, Titanium intake valves in 2.3 diameter, 1.6 rockers, tunnelram with twin 750 carbs. 2 1/8 headers 35 inch long, 4 inch collecters. Use a small combustion chamber with a big dish piston for 11/1 compression?
Yes! Greg! and this would go in a 63 Dodge Polara...vintage S/S clone
[Re: B1Fish540]
#1350313
12/17/12 04:10 PM
12/17/12 04:10 PM
Posts: 778 Sherwood park, Alberta.
go green
Big inch nitrous engines days are numbered in heads up racing , a turbo small block will eat most 844cid nitrous cars at the same weight . (And be easier to maintain and cost less . ) Just look at the 2012 SCSN pro street race .
[Re: joshking440]
#1350315
12/17/12 06:25 PM
12/17/12 06:25 PM
Posts: 105 ontario
Clockwork
ontario
I liked the b-1 heads but they just didn't make enough power to go TS racing naturally aspirated. Anyone have any used Predator heads for sale..
572ci B1 7.90 172MPH
[Re: Clockwork]
#1350316
12/17/12 06:45 PM
12/17/12 06:45 PM
camastomcat
Salt Lake City
How fast do you need to be in T/S? And at what weight?
[Re: camastomcat]
#1350317
12/17/12 11:55 PM
12/17/12 11:55 PM
Posts: 105 ontario
Clockwork
ontario
7.40-50
I am 2650lbs. Just can`t get there with my B1 stuff.
[Re: Clockwork]
#1350318
12/18/12 02:08 AM
12/18/12 02:08 AM
Posts: 698 Alberta Canada
Edge
Alberta Canada
7.90 was with spray I am assuming ? What will the car run N/A ?
76 Duster
work in progress
[Re: Edge]
#1350319
12/18/12 05:58 PM
12/18/12 05:58 PM
Posts: 51 Vacaville, Ca
Kenny705K
Vacaville, Ca
I would assume that's N/A......Our 572 B1 at 2,500 pounds has run 7.68 with a Lenco, 7.90's with a glide
