Help needed from you pros to complete 446 build. #135018
10/11/08 11:02 AM
10/11/08 11:02 AM
so.fla
OldRam Offline OP
OldRam  Offline OP
so.fla
To all of you most knowledgeable 440 pros out there, I am in need of help to complete this very
long drawn out project. My knowledge level doesn't
extend into the world of big blocks, thus, I am seeking your opinions and advise. Here are the stats.
1. 86 DodgeRam 440 .030 over 440Source all forged
2. 10.5 to 1 compression
3. Truck weighs 4055 lbs.
4. Tire size is 33x12.50R15
5. Rear gears 410 Positraction (Shortbed 4x4)
6. Stealth Alum. heads 2.14 valves
7. Will be using 250hp Nos setup
The $ 64,000.00 question is this. With this information, is there a formula one would use to determine cam size ( I would like a roller )and the appropiate manifold? This truck although show quality will be driven daily and it has factory A/C and power brakes thrown in the mix.
Gas price and consumption is not going to be a consideration here. I DO NOT want to be BEAT UP by local diesel maniacs. I want it to be suprbad
but still have my a/c and run on pump gas if possible. Thank you all for whatever advise you may offer. I anxiously await your replies.I also
have a 440 tunnel ram(just a consideration)Thx.
OldRam
Re: Help needed from you pros to complete 446 build. [Re: OldRam] #135019
10/11/08 11:42 AM
10/11/08 11:42 AM
West Central Indiana
Mr.Runum Offline
Mr.Runum  Offline
I would suggest calling Comp Cams and give the "Real Experts" all of your specs and your intentions and let them help pic a cam or custom grind one for you. . Very nice truck.
Mr. Runum
69 RoadRunner 383 4spd coupe, 06 Hemi Daytona Charger, 08 6.7 RAM QC short bed 3/4 4X4
Re: Help needed from you pros to complete 446 build. [Re: OldRam] #135020
10/11/08 12:21 PM
10/11/08 12:21 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Sounds like you need to call the supercharger store and talk to them.
Re: Help needed from you pros to complete 446 build. [Re: jbc426] #135021
10/11/08 12:46 PM
10/11/08 12:46 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
At 10.5:1 static comp this motor isn't a great candidate for a super charger, and I don't know why he'd need one.
As for cam selection, you need to talk to a pro.
A custom ground cam for sure.
If you really want a roller, THE guy with rollers seems to be Scott Brown.
I'm not sure what his contact info is these days. You can probably find it with a search of the "Unlawful's race only" threads
Re: Help needed from you pros to complete 446 build. [Re: OldRam] #135022
10/11/08 06:55 PM
10/11/08 06:55 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
557 solid? what stall? nice looking truck
