413 with Dual Fours??
#1349648
12/11/12 06:22 PM
12/11/12 06:22 PM
Posts: 117 Alberta, Canada
DRAG
Alberta, Canada
I'm looking to put a dual four barrel setup on my 65 Chrysler 300. There are 4 different intakes to go with that were put on 413s & I'm looking for input from past experience &/or knowledge of what what work best. If has no A/C. Intake, Carbs, exhaust? I want a setup that looks relatively stack. ![](/ubbthreads/images/graemlins/shruggy.gif)
Re: 413 with Dual Fours??
[Re: gch]
#1349651
12/12/12 01:01 AM
12/12/12 01:01 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
The edelbrock will likely out perform the stock one by a mile.{quote}
Depends on your end goal !
Depends or your end goal.
![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: 65superstock]
#1349653
12/12/12 09:22 PM
12/12/12 09:22 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Not sure if the newer carbs will bolt to the old OEM dual quads. I know the AFB changed bolt patterns at some point, not sure when though.
[Re: Supercuda]
#1349654
12/12/12 09:28 PM
12/12/12 09:28 PM
Posts: 304 Portland, Oregon
Digger73
Portland, Oregon
We used to drill the second bolt pattern in the base of AFBs. If I remember right there was plenty of space for both patterns.
I live with fear everyday but, sometimes she lets me race!
[Re: lewtot184]
#1349656
12/12/12 11:12 PM
12/12/12 11:12 PM
Posts: 5,907 Athens, Greece
Pyper70
Athens, Greece
How old is that CH28 Lewtot? My intake has cast between the runners...Looks like you can see the valleypan on your setup
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: Supercuda]
#1349660
12/13/12 02:35 AM
12/13/12 02:35 AM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
I get the smaller 4131's frequently at the swap meets. $5-$30. 4 1/8" tops.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: DRAG]
#1349662
12/13/12 12:42 PM
12/13/12 12:42 PM
62maxwgn
Blair County,PA
Thanks for the feedback guys! Would I need to change out the fuel pump? Do the repro air cleaners fit the edelbrock carbs?
There are two different bases,the 62 early 63 used the 3447 AFB with small air horn,the mid 63 and 64 used the 3705 which has the same size air horn as the Edelbrock.
