Re: Small port w8???
[Re: MR_P_BODY]
#1349283
12/30/12 02:20 AM
12/30/12 02:20 AM
Posts: 1,784 PA
W5DART66
PA
[Re: W5DART66]
#1349284
12/30/12 02:22 AM
12/30/12 02:22 AM
Posts: 1,784 PA
W5DART66
PA
[Re: W5DART66]
#1349285
12/30/12 02:23 AM
12/30/12 02:23 AM
Posts: 1,784 PA
W5DART66
PA
[Re: WHITEDART]
#1349289
12/30/12 02:06 PM
12/30/12 02:06 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Wow I think those will go over 400 with those large ports.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1349290
12/30/12 05:41 PM
12/30/12 05:41 PM
Posts: 1,784 PA
W5DART66
PA
[Re: WHITEDART]
#1349292
12/30/12 07:38 PM
12/30/12 07:38 PM
Posts: 1,784 PA
W5DART66
PA
[Re: emarine01]
#1349294
12/31/12 12:07 AM
12/31/12 12:07 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Is that intake port floor leaning towards the bore? So are you thinking about doing the EMC this year? You know I am...but I would have to go even if I had a pooch this time for sure!
Brian Hafliger
[Re: W5DART66]
#1349296
12/31/12 01:37 AM
12/31/12 01:37 AM
Posts: 1,784 PA
W5DART66
PA
[Re: MR_P_BODY]
#1349297
01/11/13 09:32 PM
01/11/13 09:32 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
hey would like to thank brett miller for all his hard work and time he put in these heads.. I took the heads to QMP RACING hear in so cal ..and had them flow this set of small valve w8s [[2.15]] intake .. brad at qmp was very happy with these number @lift flow 500 310 550 340 600 364 650 379 700 386 and this was flowed on a 4.200 bore fixture the flow bench at QMP is very tight my cnc 360-1 raise ports went 313 cfm on this same bench .. they were very impressed with bretts work .this port would reach 400cfm with a bigger valve
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: Just-a-dart]
#1349300
01/11/13 11:04 PM
01/11/13 11:04 PM
Posts: 1,784 PA
W5DART66
PA
Thanks for the update Shiloh wish had bigger valve but they will run hard. I am more upset that they did not pull to .900 or 1.00" of lift. I know this has been long road for you glad to see it starting to work out for you. ;-) Over 380 .....
