Best no cutting tank baffling for in-tank efi pumps?
#1348393
12/09/12 12:31 PM
12/09/12 12:31 PM
Posts: 3,334 West Coast, USA
jbc426
West Coast, USA
I have a new, stock 1968 a-body gas tank I was going to use the sending unit/fuel pick-up hole to install a small in-tank electric fuel pump through for my efi conversion. I'm using a return style fuel system.
The car is set up for occasional road course and spirited open road driving.
After reading up on the subject, I understand I will need some baffling to control fuel starvation when I get below 1/4 tank.
Can I get away with using a foam type sleeve or any other effective method I can insert through the existing opening? Should give up on the easy way and cut the top of the tank and install a trap-door type metal baffle attached to the bottom of the tank?
Or, should I cut the bottom of the tank and weld in a small sump on the bottom with baffles?
1970 Plymouth 'Cuda #'s 440-6(Stock drivetrain in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's & EFI. 1968 Plymouth Barracuda Convertible Paxton Boosted 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 3.91's (closest thing to an automatic 5 speed going)
Re: Best no cutting tank baffling for in-tank efi pumps?
[Re: jbc426]
#1348394
12/09/12 01:48 PM
12/09/12 01:48 PM
Posts: 4,848 Memphis
HemiRick
Memphis
read this recent thread on the same subject thread
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: demon]
#1348402
05/09/13 08:13 PM
05/09/13 08:13 PM
Posts: 1,179 Canada
demon
Canada
[Re: demon]
#1348403
05/09/13 08:14 PM
05/09/13 08:14 PM
Posts: 1,179 Canada
demon
Canada
[Re: rapom]
#1348407
05/10/13 01:13 PM
05/10/13 01:13 PM
Posts: 75,422 A gulag near you.
JohnRR
A gulag near you.
Does the tray prevent you from running the tank to low? Looks like you could running out of gas at an 1/8 tank.
No, it's purpose is to stop the pickup from becoming uncovered when you are low on fuel and taking a sharp turn , accelerating fast or hard braking.
[Re: rapom]
#1348408
05/10/13 03:33 PM
05/10/13 03:33 PM
Posts: 9,235 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I was wondering the same thing since there are no visible holes for fuel to get into that tray !!
[Re: Stanton]
#1348409
05/10/13 04:53 PM
05/10/13 04:53 PM
JohnRR
A gulag near you.
Holes in the tray would somewhat defeat the purpose of it , keeping the pickup submerged , but that could be a problem , need to see another angle of the pickup ...
EDIT ... I just went to tanks inc site , that pickup has a hole on the left side , can't be seen in the picture posted above , right at the bottom , looks to be maybe 1/2" , 3/8" ?
