Re: rallley dash cluster problem
[Re: cornet684me]
#134821
10/12/08 03:50 PM
10/12/08 03:50 PM
Posts: 216 united kingdom
Simonic
united kingdom
Good luck finding one at a swap meet. Make sure you check it out good before fitting. The gauges are easily toasted............ i know i've done it ![](/ubbthreads/images/graemlins/thumbs.gif)
Keeping the Bee Buzzin'
[Re: cornet684me]
#134825
10/16/08 12:54 PM
10/16/08 12:54 PM
Posts: 556 Arkansas
GregGarner
Arkansas
We can fix it for you, or you can try to solder it yourself.
If you have another junk cluster around you can sometimes transplant a non-broken pin.
Sometimes you can put a piece of copper wire inside the broken pin, then solder from the back of the board to make it be strong again. The wire inside the pin will make a good place for solder to connect the broken piece to the piece still on the board.
GregGarner www.rt-eng.com Home of the mopar solid state limiter adn tach repair kit
