Re: rallley dash cluster problem [Re: cornet684me] #134816
10/10/08 10:55 PM
10/10/08 10:55 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The one I have goes in my 68 Coronet... Swaps, Ebay or Year One$$$$$$ 68 Chargers all had Rally dashes so it's an easier harness to find...
Re: rallley dash cluster problem [Re: 1_WILD_RT] #134817
10/10/08 10:57 PM
10/10/08 10:57 PM
Brandon, Ms
cornet684me Offline OP
Brandon, Ms
how much do they go for? is it better to buy a new verus going with a used one?
Re: rallley dash cluster problem [Re: cornet684me] #134818
10/10/08 11:05 PM
10/10/08 11:05 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
New from Year One around $550, used typically $75-$150ish, if you find a clean one I'd run it, most have burned connectors & cut/spliced wires...My original was crusty, I scored a super nice one at a Pick-N-Pull yard ten years ago when I didn't need one & when I tried selling at a swap nobody would give me $50.00 so I stuck it on the shelf & found this car that needed it..
Re: rallley dash cluster problem [Re: 1_WILD_RT] #134819
10/10/08 11:15 PM
10/10/08 11:15 PM
Brandon, Ms
Brandon, Ms
well looks like the new one is out of the picture for me, i will hitting the swap meets! i am headed to the cruisin the coast in biloxi ms tommorrow, maybe i will find a mopar guy down there.
thanks for all you input
Re: rallley dash cluster problem [Re: cornet684me] #134820
10/10/08 11:20 PM
10/10/08 11:20 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
No problem! Have fun in Biloxi...
Re: rallley dash cluster problem [Re: cornet684me] #134821
10/12/08 03:50 PM
10/12/08 03:50 PM
united kingdom
Simonic Offline
Simonic  Offline
united kingdom
Good luck finding one at a swap meet.
Make sure you check it out good before fitting.
The gauges are easily toasted............ i know i've done it
Keeping the Bee Buzzin'
Re: rallley dash cluster problem [Re: Simonic] #134822
10/12/08 07:06 PM
10/12/08 07:06 PM
Brandon, Ms
Brandon, Ms
how do i make sure a cluster is good?
Re: rallley dash cluster problem [Re: Simonic] #134823
10/12/08 07:08 PM
10/12/08 07:08 PM
Brandon, Ms
Brandon, Ms
are you saying, the wiring harness can be bad and ruin my cluster before i know it?
Re: rallley dash cluster problem [Re: cornet684me] #134824
10/12/08 07:10 PM
10/12/08 07:10 PM
Brandon, Ms
Brandon, Ms
i think that i already have a problem, one of the 5 brass prongs on the back of the cluster, one of the prongs have broke off, can this be replaced or should i just try to solder myself?
Re: rallley dash cluster problem [Re: cornet684me] #134825
10/16/08 12:54 PM
10/16/08 12:54 PM
Arkansas
GregGarner Offline
GregGarner  Offline
Arkansas
We can fix it for you, or you can try to solder it yourself.
If you have another junk cluster around you can sometimes transplant a non-broken pin.
Sometimes you can put a piece of copper wire inside the broken pin, then solder from the back of the board to make it be strong again. The wire inside the pin will make a good place for solder to connect the broken piece to the piece still on the board.
GregGarner
www.rt-eng.com
Home of the mopar solid state limiter adn tach repair kit
Re: rallley dash cluster problem [Re: GregGarner] #134826
10/17/08 10:54 PM
10/17/08 10:54 PM
Brandon, Ms
Brandon, Ms
i have just bought a complete dash with cluster, so i am hoping the with the 2 clusters i will be able to fix, thanks for the input
